So I'm finally acquiring funds , bought a new PGW windshield looks quite nice .
I had a large crack and you can't register your car with with a good windscreen.
I also bought a new mass air flow sensor Bosch and rebuilt alternator for 75$ from a friend
I'm having a charging issue that I currently need help with if anyone has any advice ,
I bought some never used Eibach pro Kit from by buddy which can be up for sale if any of you are interested will post pics of them I might throw them on to see how they feel ,
Some current pics of the car and the interior
Need to paint my wheels any suggestions ??
Back to the charging issue. So when I first got the car running I couldn't find the blue wire the went to the d+ - neg terminal on the alternator, somehow it went missing i remebered pulling of when i pulled my motor but I wasn't worried about that because I couldn't even drive my car because it wasn't insured and the fuel pump went out on me. So one day after I had got my new fuel pump installed I found the stupid wire hiding in the insulation of the red wire with the wire ripped and shorter in length like 6 inches , so I soldered a new wire in , and I installed the connections on my alternator , when I was finished I started the car all the lights on the cluster were on including my park brake that stayed lit when it was disengaged and went brighter when pulled . Also the battery light was on , (new battery) and the brake fuild , abs , brake lining light . I then went and accuired a rebuilt 85$ alternator I installed it and all the lights went off on the dash , thinking my car was charging I drove it around realized the cars lights going dim took it home , and turned it off and turned it back on , no start , so I charged the battery thinking maybe the alternator wasnt working because the battery was to low or something , so I drive over to orielly after it charged and I get my alternator tested , it' read 12.59 volts and the voltage regulator was only putting out 30 amps when it supposed to be putting out over 100
Lowered the whip today and got two used hankook 215/45/17 tires for the front .
So much smoother I installed the rear springs
Here's a before picture of the ride height
currently just got stranded due to a frayed accelerator cable
current list of whats things i have done to the car and replaced , never decided to make one till now
1.255 walbro fuel pump
2.black headliner
3.e36 window switches
4.red tails
5.new steering rack boots
6.new tie rods
7.Mtech 1 e30 wing
8.new alternator (still not charging)
9.new Bosch F.P.R.
10.ported and polished head intake and exhaust
11.new mass air flow sensor
12.new bearings
13.full engine reseal
14.new guibo
15.hid kit 8000k
16.new windshield
17.sport seats
18.rear headrests
19.short shifter
20.eibach pro kit
21.17inch enkie wrapped in Hankooks and Michelins
22.fresh engine bay paint
23.NEW accelerator cable
24.m tech 1 steering wheel
that's it so far , there will be much more in the future still need to pick up my car off the side of the road it broke down because the accelerator cable was sticking and i didn't feel like blowing my freshly rebuilt motor
My friends 318 slammed enough ???
I installed my friends vogtland springs and new shocks looks really good and had a nice drop
A pic before I put my front springs In
I know my tire needs to be shined
