FORGED FULLY 🐬 grey S50,shaved, KW, brembos, garret g30/770 fr&rear 5 lug,
  • e30m20TurbO7
    • 1203
    #151
    • e30m20TurbO7
      • 1203
      #152
      Fuck my life moment
      • Mlarsen
        • 4082
        #153
        That sucks man, hope everything works out.
        • Cronopoulos
          • Jul 2011
          • 2187
          #154
          Don't take it personal man, shit happens when you build motors. I have fucked up my share of things and mother nature has provides plenty of hammers to my nails as well... You live and learn even though it's not your fault all the time ;)
          Find the problem, fix the problem, enjoy!
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • kid325e
            • Sep 2007
            • 6421
            #155
            Damn!! Sorry to hear the bad news. Glad to see you so quick to take responsibility. Keep your head up. I'm sure you'll be back on the road by summer time.
            Sent from my LG-P999 using Tapatalk 2
            clutchCTRL!
            Move with a purpose.
            - 1991 325iX 4dr/5spd
            - 2000 323i AT
            2016 Mazda CX3 Sport AWD
            • Court M3
              • Jan 2004
              • 6713
              #156
              Good job taking responsibility as others have said, keep at it, only way you are going to learn is by getting in there and finding out what's wrong.
              Continuous For Sale Thread
              323i s50
              • Vtec?lol
                • Dec 2009
                • 3278
                #157
                yeah dude. Never get emotional into e30s. Never. And never get online and start crying about it either.
                More than likely if that cam lobe went dry then you have a worn cam and rocker. Replace, adjust, and enjoy the rest of your build.
                Sacrifice and hard work don't guarantee perfect results.
                • tinkwithanr
                  • Jun 2010
                  • 377
                  #158
                  Sorry to hear about your luck. But I don't think a clogged oil sprayer would cause the valve and valve seat to get worn. There shouldn't really be any oil there (unless your seals/guides are worn) so the lack of oil wouldn't effect it. The oil spray bar is there to supply the rocker and cam face with oil, so those are the two parts I would point to for any bad noises. Pull the head and take out the cam and rocker shaft to see what they look like.
                  Tinker Engineering - 2014
                  Mica - 2000 BMW 323i - The one that started it all
                  Fiona - 1975 BMW 2002 - The Definition of Project Creep
                  Heidi - 1988 BMW M5 - The piece of BMW history
                  Silvia - 2013 Subaru WRX - Stock, for now
                  • e30m20TurbO7
                    • 1203
                    #159
                    So I have a bad rocker and a bad cam I'm assuming ,
                    I've got all good compression in all the cylinders
                    #1 92
                    #2 90
                    #3 89
                    #4 91
                    #5 93 cylinder with rocker noise
                    #6 90
                    I think I have a worn rocker and or cam
                    How can I make the noise qeuiter , I adjusted my valves way to tight when I first stabbed them in , then once I adjusted to correct spec rocker got louder
                    I really don't want to spend any money on diagnosing fees .
                    What do I look for on a worn rocker
                    • FLG
                      • Sep 2011
                      • 3165
                      #160
                      Those are some really bad compression numbers.
                      Who did the machine work when you built the motor? New rings?
                      If you add some oil in the cylinders do comp number go up? If they don't its a head issue. If they do (by a substantial amount) its a ring issue.
                      Sent from my Galaxy Nexus using Tapatalk 2
                      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                      • 2mAn
                        SeΓ±ior Mod
                        • 20250
                        #161
                        they say do it right or do it twice... at least you're young. you have plenty of time to make mistakes. key is not make the same mistake twice. in your case, tearing down the motor was good because you learned how to put it back together and succeeded. problem was you re-used piston rings and bearings. when you have it that far apart, its best to spend a little extra money on new parts.
                        edit: also take some goof off, or oven cleaner to that one painted wheel so they are all silver
                        Simon
                        Current Cars:
                        -1966 Lotus Elan
                        -1986 German Car
                        -2006 Volkswagen Jetta TDI
                        Make R3V Great Again -2020
                        • e30m20TurbO7
                          • 1203
                          #162
                          First of all, I used brand new bearings on the rods and mains , there's nothing wrong with re-using piston rings off a motor that ran and if its going on to the same cylinder that it began in , I have perfect compression , no rod knocks nothing was half ass on my build .
                          The only thing I should have done was buy a new oil pump.
                          New bearings
                          New guides
                          New stem seals
                          3 angle valve job
                          I have hundreds in just machine shop fees .
                          All new seals throughout the whole motor without a single leak , I didn't do anything incorrect on my build.
                          My oil squirter tube was clogged from debris in the oil so I burned a cam lobe and rocker , wooptee doo
                          I spent more money than you could possibly think is possible for this motor.
                          Reusing my rings may have been a risk but how come I have perfect compression , hmmmmmm well I have nothing to prove to you , but I take offense to people who have negitive opinions to say how about how I built my engine when I doubt you even attempted something as challenging and time consuming , as I have .
                          My rims are multi colored because its below 35 outside . I doubt goo off is going to take 3 layers of paint off my wheels .
                          • e30m20TurbO7
                            • 1203
                            #163
                            I did a cold dry compression test with all the spark plugs out with the throttle wide open to get more a more accurate reading , when the throttle is closed it changes compression . I'm running a stroked eta block on a 885 head
                            The compression is going to be lower than normal .
                            How come I have equal pressure that I'm not losing.
                            None of those valves leak and it was done by a quality shop that's been around for 50 years
                            • e30m20TurbO7
                              • 1203
                              #164
                              But if someone will take 30 minutes of time with your iPhone and a 10mm socket
                              Will someone send me a video of your e30 running with the valve cover off and close up of the squirter tube , my fellow mechanic friend thinks my oil pump is weak and he thinks that' because my oil light flickers at idle so because it's weak is why the cam lobe went dry and that the oil squirter isn't squirting properly due to weak pump. I disagree because I found my tube was clogged over cylinder 5 so I blew it out and ran it with fresh oil and filter , and it would drip more than squirt when I would feather the idle with the
                              Valve cover off but it would squirt more when it's revved slowly but my friend thinks that the squirting isn't consistent due to a tired pump , anyone have any opinions about this .
                              He thinks there's no point in fixing the rocker and cam with out replacing the oil pump, because he's confident the pump is the suspect
                              IMO the oil tube clogged on 5 because I had THICK break in oil in it and everyone knows how dirty break in oil gets
                              • FLG
                                • Sep 2011
                                • 3165
                                #165
                                I know they are within correct tolerances between cylinders but you a stock m20 should be around 140-150 psi... unless you build this motor with lower compression in mind? Yes they are close to each other but far off factory spec.
                                I'll be honest I couldn't read thru pages of thread on my phone to see what the final specs wound up being.
                                Never mind just re read your last post. Yes a 885 head on an eta block will do that.
                                Hook up a mechanical gauge and watch your oil pressure. Can't necessarily rely on the stock warning light for being completely accurate.
                                I think the guys at catuned uploaded a video of an m20 running without a valve cover not long ago. Maybe do a search. I don't remember where it was posted or the title.
