e30 Turbo from BAHRAIN
Originally posted by euro2fast4u View Postwhat ecu are you using to control this?
Originally posted by evandael View PostI'm really interested in how you're running an M20 with a 1JZ harness and ECU. How much modification did you need to do, either on the wiring side, or on the engine side (for sensors and other things) to get it to work?
Well, first, it's out from 1jz non vvti single coil so i'm keeping the stock e30 coil and disterbuter ...
You need from the full wiring harness (ecu, igniter, map sensor, crank shaft sensor to be installed behind the alternator "oil pump cup" and you can advance/retard some timing, tps switch, and the wiring for the injectors, temp sensor, etc...)
You have to be a little experience in electrical issues and everything will be ok ;)
Engine bay is so clean and quiet with that wiring + no afm or maf
Originally posted by jo3y View Postnice work
more info on your turbo. How does it spool? Is your exhaust manifold split pulse?318iS Track Rat :nice: www.drive4corners.com
very nice build. Great looking car95 7.1L 16V E36 M3
Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
LIKE my Facebook Page! CLICK HERE
Originally posted by downforce22 View Postmore info on your turbo. How does it spool? Is your exhaust manifold split pulse?
That manifold will be replaced soon as of leaks and I'm hating the seat of the turbo like this :(
Originally posted by kalib0y View Postvery nice build. Great looking car
Originally posted by sayed ali View PostTurbo spools very strong, full boost at 3500rpm "it should be around 3200rpm max, but due to some boost leaks"
Thank you sir :)
T70 Turbocharger
Condition - Brand New!
Manufacturer - JDM Sport
Application
Ideal for large (3.0L-6.0L) displacement engines
Features
Stage 4 turbo capable of 300-500 HP
Capable of 25-35 PSI output at peak power performance
Wet float bearing
External wastegate
Compressor
Inlet = 4"
Intake (ID / OD) = 2" / 2.5"
Inducer = 56.2 MM
Exducer = 72.9 MM
Trim = 59
A/R = 0.70
Turbine
Outlet = 2.5"
Turbo flange = T3 [twin entry divided flange]
Downpipe flange = 2.5" V-band
Inducer = 73.9 MM
Exducer = 58.3 MM
Trim = 62
A/R = 0.84
Center Section
Oil cool system
Oil feed = T3
Oil return = T3318iS Track Rat :nice: www.drive4corners.com
