e30 Turbo from BAHRAIN
  • sayed ali
    • 762
    #31
    Fixed the ecu, it was burned due to a short in the wiring...
    Some cleaning for the wheels :)
    Nuts removed
    Before..
    After..
    Finished product
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • sayed ali
      • 762
      #32
      Today's updates:
      Interior lighting...
      M20B28 Turbo
      My Build Thread
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #33
        Looking good!
        • sayed ali
          • 762
          #34
          Did a e36 windows switches conversation ...
          Before ...
          After :)
          Which is better :P
          M20B28 Turbo
          My Build Thread
          • MrNatural
            • Apr 2008
            • 237
            #35
            Good job...love it!
            • euro2fast4u
              • 545
              #36
              what ecu are you using to control this?
              • sayed ali
                • 762
                #37
                1jz wiring, I got it cheap and it's map sensor.. much more better than the stock afm...
                M20B28 Turbo
                My Build Thread
                • sayed ali
                  • 762
                  #38
                  New update:
                  Bought a HKS FCD
                  Tuning is coming soon :)
                  M20B28 Turbo
                  My Build Thread
                  • evandael
                    • Oct 2009
                    • 2881
                    #39
                    I'm really interested in how you're running an M20 with a 1JZ harness and ECU. How much modification did you need to do, either on the wiring side, or on the engine side (for sensors and other things) to get it to work?
                    • jo3y
                      • Nov 2011
                      • 80
                      #40
                      nice work
                      MR2/Camaro Strut DIY
                      http://www.3seriestech.com/viewforum.php?f=22
                      • sayed ali
                        • 762
                        #41
                        Well, first, it's out from 1jz non vvti single coil so i'm keeping the stock e30 coil and disterbuter ...
                        You need from the full wiring harness (ecu, igniter, map sensor, crank shaft sensor to be installed behind the alternator "oil pump cup" and you can advance/retard some timing, tps switch, and the wiring for the injectors, temp sensor, etc...)
                        You have to be a little experience in electrical issues and everything will be ok ;)
                        Engine bay is so clean and quiet with that wiring + no afm or maf
                        Originally posted by jo3y
                        nice work
                        Thanx man :)
                        M20B28 Turbo
                        My Build Thread
                        • downforce22
                          • Aug 2009
                          • 3191
                          #42
                          more info on your turbo. How does it spool? Is your exhaust manifold split pulse?
                          • kalib0y
                            • Dec 2004
                            • 3620
                            #43
                            very nice build. Great looking car
                            95 7.1L 16V E36 M3
                            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                            LIKE my Facebook Page! CLICK HERE
                            • sayed ali
                              • 762
                              #44
                              Turbo spools very strong, full boost at 3500rpm "it should be around 3200rpm max, but due to some boost leaks"
                              That manifold will be replaced soon as of leaks and I'm hating the seat of the turbo like this :(
                              Thank you sir :)
                              M20B28 Turbo
                              My Build Thread
                              • downforce22
                                • Aug 2009
                                • 3191
                                #45
                                Thank you sir :)
                                Is your turbo the same as this one?
                                T70 Turbocharger
                                Condition - Brand New!
                                Manufacturer - JDM Sport
                                Application
                                Ideal for large (3.0L-6.0L) displacement engines
                                Features
                                Stage 4 turbo capable of 300-500 HP
                                Capable of 25-35 PSI output at peak power performance
                                Wet float bearing
                                External wastegate
                                Compressor
                                Inlet = 4"
                                Intake (ID / OD) = 2" / 2.5"
                                Inducer = 56.2 MM
                                Exducer = 72.9 MM
                                Trim = 59
                                A/R = 0.70
                                Turbine
                                Outlet = 2.5"
                                Turbo flange = T3 [twin entry divided flange]
                                Downpipe flange = 2.5" V-band
                                Inducer = 73.9 MM
                                Exducer = 58.3 MM
                                Trim = 62
                                A/R = 0.84
                                Center Section
                                Oil cool system
                                Oil feed = T3
                                Oil return = T3
