e30 Turbo from BAHRAIN
  • sayed ali
    • 762
    #46
    Originally posted by downforce22
    Is your turbo the same as this one?
    T70 Turbocharger
    Condition - Brand New!
    Manufacturer - JDM Sport
    Application
    Ideal for large (3.0L-6.0L) displacement engines
    Features
    Stage 4 turbo capable of 300-500 HP
    Capable of 25-35 PSI output at peak power performance
    Wet float bearing
    External wastegate
    Compressor
    Inlet = 4"
    Intake (ID / OD) = 2" / 2.5"
    Inducer = 56.2 MM
    Exducer = 72.9 MM
    Trim = 59
    A/R = 0.70
    Turbine
    Outlet = 2.5"
    Turbo flange = T3 [twin entry divided flange]
    Downpipe flange = 2.5" V-band
    Inducer = 73.9 MM
    Exducer = 58.3 MM
    Trim = 62
    A/R = 0.84
    Center Section
    Oil cool system
    Oil feed = T3
    Oil return = T3
    It's very similar to mine except this: A/R = 0.84 , Mine is 0.63
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
    • sayed ali
      • 762
      #47
      Bored = New goodies ... :)
      M20B28 Turbo
      My Build Thread
      • sayed ali
        • 762
        #48
        Some interior shots ...
        Black painted boost gauge
        Carbon fiber close shot :)
        M20B28 Turbo
        My Build Thread
        • bernzpeed
          • 3917
          #49
          Before ...
          After :)
          Which is better :P
          should've used the actual 2 buttons trim instead of individuals like that.
          89 E30 S52
          Transaction Feedback.
          • sayed ali
            • 762
            #50
            New engine bay update & new fitting in the turbo housing instead of in the piping
            After..
            New goodies... MSD
            M20B28 Turbo
            My Build Thread
            • squidmaster
              • Aug 2011
              • 2666
              #51
              nice stuff! any videos?
              • el bimmer
                • 900
                #52
                Wow this is a bad ass project!
                • sayed ali
                  • 762
                  #53
                  Long time didn't post on here, updates:
                  - Currently I'm working on the suspension
                  - Next step is the tuning
                  Some recent engine bay shots ..
                  M20B28 Turbo
                  My Build Thread
                  • sayed ali
                    • 762
                    #54
                    Update:
                    *New oil catch can tank
                    *finished the IC piping work
                    *New set of plugs + oil (for the dyno time)
                    *Installed the HKS FCD
                    Making sure that everything is fine before take it to the dyno by the end of November, as I have another liabilities now, and I'm waiting for the good weather :)
                    I hope I hit 350whp on something around 1 - 1.2 Bar
                    M20B28 Turbo
                    My Build Thread
                    • jaywood
                      • Jul 2010
                      • 4528
                      #55
                      Looks great...I like the heat shield...what's that all about? Cut up stove pot? :p
                      • sayed ali
                        • 762
                        #56
                        Updates:
                        *Got the oil catch installed
                        *Converted the stock plugs wires to be usable with the closed end plugs like:
                        -As of it's very difficult to find the open ended ones over here..
                        I took out the plastic from the stock wires that goes to the plugs, cut it, fitted that piece on it
                        *Bought new set of NGK iridium plugs
                        *MSD 6a
                        *MSD coil blaster 2
                        Checking around leaks, set the boost, etc.. before the tuning in the end of this month hopefully ..
                        M20B28 Turbo
                        My Build Thread
                        • sayed ali
                          • 762
                          #57
                          Update:
                          Cleaned my BBs & Painted them (Gold)
                          Before:
                          In progress...
                          After:
                          Side view..
                          M20B28 Turbo
                          My Build Thread
                          • sayed ali
                            • 762
                            #58
                            Received my BBs caps just now
                            M20B28 Turbo
                            My Build Thread
                            • FLG
                              • Sep 2011
                              • 3165
                              #59
                              Looking good!
                              btw with the plugs, all you need to do is unscrew the ends (most plugs are designed this way) i cant think of a single plug here that comes with no caps on the end off hand, we just grab a pair of pliers and unscrew em, some are non removable though.
                              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                              • sayed ali
                                • 762
                                #60
                                Most of them over here are irremovable,, that's why I did this way
                                M20B28 Turbo
                                My Build Thread
