★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
  • shameson
    • Jun 2012
    • 1507
    #1126
    Man, that's a clean sandwich. Why rebuild wheel when you can build sandwich
    '84 Alpine 325e (Gone)
    '91 Alpine 318i (Gone) Click Here
    '92 Alpine 325i Cabrio (Gone) Click Here
    '91 Alpine 318is
    • lambo
      Captain Scene Points
      • 10953
      #1127
      List of things to do now that I has money:
      1. Fix squeaky rear brake
      2. Fix Futura's
      3. Emissions
      4. Loud exhaust
      5. Finally respray mirrors and trim
      6. All red tails
      7. Neon
      • MPLFoster
        • May 2013
        • 1490
        #1128
        ooooOOOOoooohhh...neon!
        in for fixed futura's.
        form.follows.function IG @mplfoster
        • lambo
          • 10953
          #1129
          Gonna get the tires unmounted sometime this week and start the dismantle/polishing process.
          • 2mAn
            Señior Mod
            • 20878
            #1130
            Finish these by next thursday! haha With the skills it took to make that sandwich, fixing the wheels will be easy
            Simon
            Current Cars:
            -1966 Lotus Elan
            -1986 German Car
            -2006 Volkswagen Jetta TDI
            Make R3V Great Again -2020
            • lambo
              • 10953
              #1131
              It's possible. Highly unlikely though lol.
              • lambo
                • 10953
                #1132
                I've also decided I really need to do a Z3 1.9 rack, rebuilt power steering and a smaller steering wheel. I recently drove a buddies S2000 fuhraze car around and it reminded how stupidly slow and sloppy my steering is...
                • shameson
                  • Jun 2012
                  • 1507
                  #1133
                  I'm about to get started on my z3 1.9 rack install... Chris from Dungeon Motorsports sells the swap kit for non-airbag or airbag cars that comes with the necessary spacers and bolts and all I need is new tie rods. Of course I have to trim out a small part of my firewall to accomadate but all it takes is a dremel. 2.7 turns to lock is mucho better than the stock 4 turns
                  '91 Alpine 318is
                  • Azscentence
                    • Apr 2014
                    • 55
                    #1134
                    This has probably been asked tons of times, but what is your suspension setup? I'm running stock right now and I'm leaning towards a GC Coilover setup (with Konis), like yours. I'm just a little in the dark about what needs to go with it though. And, since your setup is perfect, I figured I'd ask the owner himself.
                    Thanks!
                    • Wschnitz
                      • 8089
                      #1135
                      Pretty sure lambos on GC's and Koni/Billys
                      willschnitz
                      • lambo
                        • 10953
                        #1136
                        Thanks!
                        Ground Control coilovers on shortened struts, 450f 650r or 700r (I can never remember) springs, adjustable Koni's (1547 iirc). However, if you're mostly looking to go low, I don't really recommend Ground Controls. I'd go with Broadway Static, BC, or CATuned for going low.
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #1137
                          the e46 330ci rack is another excellent rack upgrade. More available and cheaper than z3
                          all e46 330 racks are 13.7:1 (including the ZHP) and 3.0 turns L2L iirc
                          z4m coupe rack 12.8:1 (fastest rack I know of)
                          z3 non m 13.9:1 and 2.7 turns L2L
                          Shadetree30
                          • ST1G
                            • Oct 2012
                            • 6689
                            #1138
                            1. Neon
                            Fixed.
                            • AbsorbantNut
                              Non faccio funzionare questa merda
                              • Jun 2010
                              • 2491
                              #1139
                              If I don't see the neon happen in the next 2 pages I'm deleting my r3v account
                              '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                              • Azscentence
                                • Apr 2014
                                • 55
                                #1140
                                I'm looking for more of a good balance of low/dd, and I want to avoid having to weld anything like on other Coilover suspensions. I was told you don't need to weld Ground Control Coils unless you want to shorten the struts.
