Current Pictures 10/4/13
Mod List:
Exterior:
Euro Grills
Front Late Model Bumper
Front Late Model Valance
"i" Lip
Late Model Foglights
Engine:
Condor Speed Shop 24v Swap Motor + Tranny Mounts
S50 Motor and a ZF Transmission from a 95 M3
e34 Throttle Cable
e34 Oil Pan
e34 Dipstick / Pickup Tube
Mishimoto Intake Boot
SiliconeIntakes Intake Filter
2.93S LSD Differential
OE BMW Differential Axle Seals
OE BMW Drain + Fill Plug Gaskets
OE BMW Differential Gasket
Rebuilt Axles with GKN Boots
SPAL Fan + Radiator Gasket + Mounts
Mishimito Z3M S54 Radiator
UUC Stainless Steel Clutch Line
UUC Magnetic Drain Plug
Deka ETX20L Small Battery
XS Power Brass SAE Posts
"REDE30" 24v Skid Plate - Not installed
Hartge front Strut Bar - Not installed
Garagastic Delrin Rear + Shifter Bushings
OE BMW Shifter Cup
OE BMW Shifter Carrier
ECS Aluminum Water Pump Pulley
Pelican 80* Fan Switch
Bimmerworld 80* Thermostat
Meyle HD Driveshaft Center Bushing
Redline D4 ATF Transmission fluid
Redline 75-90 Differential Fluid
Exhaust:
Ebay "Supersprint" Exhaust manifolds
OBD1 Y Pipe
6" Stainless Flex Pipe
Borla XS Muffler
2.5" Stainless Steel Piping
Vibrant Dual Exit Rear Muffler
2.5" Godspeed Vband
Brakes:
944 Porsche Booster
UUC Stainless Steel Brake Lines
Centric Double Slotted rotors (Front+Rear)
Hawk HPS Pads (Front+Rear)
Rebuilt Rear Calipers
ATE Super Blue Brake Fluid
Febi E-Brake shoes
OE BMW E-Brake Hardware
Supension/Steering:
BC Coilovers (10k Front 14k Rear)
Revshift 95A "Red" 12mm Reaw Subframe Riser Kit
Revshift 95A "Red" M3 Offset Control Arm Bushings
Revshift 95A "Red" Rear Trailing Arm Bushings
Revshift 95A "Red" Differential Bushing
E30Tech "Dungeon Motorsports" Toe/Camber rear Subframe Kit
E36 Steering Rack
E30Tech Rack Swap Kit
"White325is" Rear Strut Bar
Lemforder Lower Control Arms
FAG Wheel Bearings
OE BMW Wheel Bearing Clips
BBS RS003 16x8.5 ET3
-4x 2.5 Felgenfuchs Stepped Lips
-Gunmetal Powdercoated Centers
-Elefant Supply 1/4 Height Center Caps
-BBS 70mm Center Caps
-Re-coated BBS Bolts (Cobalt Zinc)
205/45/16 General GMAXX AS-03
20mm Front + 16mm Rear Adjustable Eibach Swaybars - Not installed
Exterior/Interior/Electronics:
Recaro Seats
Crack Free Dash
Morimoto H1 retrofitted Depo Smileys
Morimoto 3FIVE Ballasts
Morimoto XB35 Bulbs
Euwerks Gauge Pod
Innovate LC-1 w/ XD-16 Wideband
Innovate Oil Pressure Gauge
Holden Oil Sensor Adapter
Innovate Boost Gauge
Innovate Coolant Temp Gauge
Mishimoto Coolant Temp Housing
Nokya 2500 fog light bulbs
Cletonius shift/ebrake boots
ZHP Weighted Shift Knob
Z3 3.0 Shift Lever
Exterior:
DSC_0027 by yahh-, on Flickr
DSC_0014 by yahh-, on Flickr
DSC_0019 by yahh-, on Flickr
DSC_0023 by yahh-, on Flickr
Interior:
Interior update by yahh-, on Flickr
Engine Bay:
I'm Sure I missed some things that I've replaced but i'll edit it in when I go through my spreadsheet.
Still Need:
Install Skid Plate
Install GE Keyless Entry
Install Rear Plastic Bumper
Install Eibach front and rear adjustable sway bars
Paint
VDO Gauges to replace Innovate G3 gauges
Big thanks to ECS Tuning, Turner Motorsports, and Blunttech for their great pricing and amazing customer service!
Mod List:
Exterior:
Euro Grills
"i" Lip
Engine:
e34 Throttle Cable
e34 Oil Pan
OE BMW Shifter Cup
Exhaust:
OBD1 Y Pipe
Borla XS Muffler
2.5" Godspeed Vband
Brakes:
944 Porsche Booster
Febi E-Brake shoes
Supension/Steering:
E36 Steering Rack
FAG Wheel Bearings
Recaro Seats
Crack Free Dash
Morimoto XB35 Bulbs
Euwerks Gauge Pod
Z3 3.0 Shift Lever
Exterior:
Interior:
Engine Bay:
Still Need:
Install Skid Plate
Paint
