325ic Calypso Euro Conversion - Houndstooth & dbilas now, MT1 & MM 3.2 stroker coming
  • 968Reckless
    • May 2013
    • 1095
    #631
    Where in western NY?
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
    • laidback93
      • Nov 2016
      • 435
      #632
      Yeah I’m curious too.
      My other half is from Niagara Falls NY.
      We’re planning a trip for next April.
      90 Bronzit 325is
      16 Black Sapphire 340i M Sport
      • bradnic
        • Jul 2012
        • 3554
        #633
        Elimira/Corning area. Just drove her back with the top down to Chicago last night to begin the teardown though. Ran like a top, AC on, cantaloupe BT 5908 with powered sub working great :-)
        Anyway, as mentioned previously the plan is to take Callie's 221k mile m20 and G260 down to Jim at Metric Mechanic for cores. Since she's running well though, the thought of having the car out of commission during the summer longer than necessary made me rethink the action plan.
        Cosmo the 86 325 coupe is ready for his 2.8 E-to-I swap... It makes more sense to tear down the parts car at this point, pull the I pistons and send them down to MM to prep them for that swap. That way I can drop off the cores and pick up the new engine, tranny and modded pistons all in one go. I'd also score some wife points by finally getting rid of the parts car.
        So I have a choice to make:
        1) get Callie back together with just a new SSSquid chip for now
        2) finish the I swap on Cosmo first and take my time on Callie - get her back on the road in the spring
        I'm now leaning towards option 2. That way my wife can use Callie for a couple of weeks before teardown and I can prep the car properly over the fall and possibly winter:
        - get the E34 ANSA/RD headers modified and ceramic coated
        - decide on standalone, injectors etc.
        - do the rear suspension bushings, which I've been putting off
        - finally get Scott at Strömung to get me the mtech1 exhaust tip adapters I still need.
        - get the same IE / Wilwood BBK Staszek grabbed for his S54 swapped 325is, in black
        would like nothing more than to have the vert totally finished mechanically. at that point there would be the electric top conversion to finish, new top canvas and paint/body.
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • jeffnhiscars
          • Jun 2011
          • 6011
          #634
          It seems to me that with the exception of the headers option 2 items can be done independently from the engine swap and each in a relatively short time.
          Alice the Time Capsule
          • bradnic
            • Jul 2012
            • 3554
            #635
            Mostly yes Jeff, but I only have one lift and can only work weekends. Once I start pulling the drivetrain I’m stuck for a while, and I’m betting the I swap is more straight forward. This way Callie stays operational for a while and I get another running e30 to toss around
            HOWTOs:
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • Cptcarisma
              • Jan 2011
              • 466
              #636
              Hey Brad,
              Just a thought. Maybe have Dan at LukeG Workshop do it for you?
              Hope you're doing well!
              CAPP. :-)
              • Staszek
                • 2533
                #637
                - get the E35 ANSA/RD headers modified and ceramic coated
                - get the same IE / Wilwood BBK @Staszek grabbed for his S54 swapped 325is, in black
                What powered sub did you get? Are your running it line off the back speakers. I am definitely going to the BT 5908. I am going to need your help this fall rewiring:)
                As for the brakes I think you will love them. I have the 16" kit but the 15" one works well. I need you to drive and feel them. Although I have a smaller 944 booster, but I am using the stock master and its perfect.
                I say finish the swap and work on Callie over the fall:)
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  #638
                  Makes perfect sense
                  • bradnic
                    • Jul 2012
                    • 3554
                    #639
                    I picked up an Infinity BassLink DC with both speaker and line level inputs. It's wired to the power amp in on the harness using a custom adapter. sounds great, but not the best choice for a vert tbh. I will be swapping the OEM amp out for a 5 channel Infinity ref4555a and a passive bass tube that will sit in the trunk. The amp swap will be plug and play.
                    And yeah gotcha covered re 5908+BT. Will be later this year as discussed.
                    Oh man I'd **LOVE** to check out your wilwoods. If the 16" kit works with my Alpinas that's where I'll land. I'll use the 'verts are heavier' excuse to justify lol. Every time I look at the stock brakes I kinda cringe.
                    That's definitely where I landed as well. Pulling the IX parts car M20 and tranny tomorrow, will use the top end on Cosmo the 325e. Guess I better figure out pistons though lol.
                    Originally posted by Cptcarisma
                    Hey Brad,
                    CAPP. :-)
                    Funny you mention LukeG.. dropped the 04 AR for what I thought were motor mount issues (vibration under acceleration). Dan found plenty to work on, but the motor mounts are fine lolol.
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • E-30k
                      • Dec 2018
                      • 9
                      #640
                      Hey Channel,
                      I have a 41331933770 (770) valance available to me (without AC cooling cut outs). I have an AC car --although AC is currently not working-- and I am planning to do the 770 install on my 87 with euro bumpers. Does any one know if I will have a mounting issue with the 770 valance? Based on his sale thread (see link below) it seems like e30rapidic had no issue mounting this part on his vert prior to cutting cooling holes in the valance . My questions are whether there is any known adjustment that would need to be made to fit the panel, and if I mount the valance is there a legitimate issue that would arise from not cutting the cooling holes for the AC system like e30rapidic did or could I leave it without the holes? Any insight would be immensely helpful.
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #641
                        So is the DB Dynamic intake actually carbureted or is it more like an ITB setup?
                        • Skarpa
                          • Jan 2013
                          • 495
                          #642
                          Replying on owners behalf: It's an ITB setup with fuel injectors. The brand is Dbilas.
                          E30 Armo "330i"
                          • bradnic
                            • Jul 2012
                            • 3554
                            #643
                            Thanks Skarpa
                            The new engine and tranny are still sitting at Metric Mechanic.. Hope to be getting back to Callie once I have Cosmo's 2.9 build on track.
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • bradnic
                              • Jul 2012
                              • 3554
                              #644
                              and... the engine and tranny are still waiting at Metric Mechanic. I pulled my parts car motor and am working a 2.9 stroker for Cosmo.. Once that's in good shape I'm pulling callie's drivetrain, driving down to MM and picking up the new bits.
                              my new gig and pending move are in the middle of all this, so will be a while longer.
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • bradnic
                                • Jul 2012
                                • 3554
                                #645
                                Just leaving this here
                                HOWTOs:
                                OEM Keys
                                MTech1 docs
                                88 ix Lach/Card
                                91 ic Calypso 3.1
                                86 Cosmo 2.7
                                OEM+ or bust!
