325ic Calypso Euro Conversion - Houndstooth & dbilas now, MT1 & MM 3.2 stroker coming
Elimira/Corning area. Just drove her back with the top down to Chicago last night to begin the teardown though. Ran like a top, AC on, cantaloupe BT 5908 with powered sub working great :-)
Anyway, as mentioned previously the plan is to take Callie's 221k mile m20 and G260 down to Jim at Metric Mechanic for cores. Since she's running well though, the thought of having the car out of commission during the summer longer than necessary made me rethink the action plan.
Cosmo the 86 325 coupe is ready for his 2.8 E-to-I swap... It makes more sense to tear down the parts car at this point, pull the I pistons and send them down to MM to prep them for that swap. That way I can drop off the cores and pick up the new engine, tranny and modded pistons all in one go. I'd also score some wife points by finally getting rid of the parts car.
So I have a choice to make:
1) get Callie back together with just a new SSSquid chip for now
2) finish the I swap on Cosmo first and take my time on Callie - get her back on the road in the spring
I'm now leaning towards option 2. That way my wife can use Callie for a couple of weeks before teardown and I can prep the car properly over the fall and possibly winter:
- get the E34 ANSA/RD headers modified and ceramic coated
- decide on standalone, injectors etc.
- do the rear suspension bushings, which I've been putting off
- finally get Scott at Strömung to get me the mtech1 exhaust tip adapters I still need.
- get the same IE / Wilwood BBK Staszek grabbed for his S54 swapped 325is, in black
would like nothing more than to have the vert totally finished mechanically. at that point there would be the electric top conversion to finish, new top canvas and paint/body.
OEM+ or bust! reelizmpro: I will always be an e30 guy.. I still do all of my own labor TrentW: There's just something so right about a well-built M20 in an E30 e30m3s54turbo: I save my money for tuner parts.
It seems to me that with the exception of the headers option 2 items can be done independently from the engine swap and each in a relatively short time.
Mostly yes Jeff, but I only have one lift and can only work weekends. Once I start pulling the drivetrain I’m stuck for a while, and I’m betting the I swap is more straight forward. This way Callie stays operational for a while and I get another running e30 to toss around
- get the E35 ANSA/RD headers modified and ceramic coated
- get the same IE / Wilwood BBK @Staszek grabbed for his S54 swapped 325is, in black
What powered sub did you get? Are your running it line off the back speakers. I am definitely going to the BT 5908. I am going to need your help this fall rewiring:)
As for the brakes I think you will love them. I have the 16" kit but the 15" one works well. I need you to drive and feel them. Although I have a smaller 944 booster, but I am using the stock master and its perfect.
I say finish the swap and work on Callie over the fall:)
Makes perfect sense
I picked up an Infinity BassLink DC with both speaker and line level inputs. It's wired to the power amp in on the harness using a custom adapter. sounds great, but not the best choice for a vert tbh. I will be swapping the OEM amp out for a 5 channel Infinity ref4555a and a passive bass tube that will sit in the trunk. The amp swap will be plug and play.
And yeah gotcha covered re 5908+BT. Will be later this year as discussed.
Oh man I'd **LOVE** to check out your wilwoods. If the 16" kit works with my Alpinas that's where I'll land. I'll use the 'verts are heavier' excuse to justify lol. Every time I look at the stock brakes I kinda cringe.
That's definitely where I landed as well. Pulling the IX parts car M20 and tranny tomorrow, will use the top end on Cosmo the 325e. Guess I better figure out pistons though lol.
Originally posted by Cptcarisma
Hey Brad,
Just a thought. Maybe have Dan at LukeG Workshop do it for you?
Hope you're doing well!
CAPP. :-)
Funny you mention LukeG.. dropped the 04 AR for what I thought were motor mount issues (vibration under acceleration). Dan found plenty to work on, but the motor mounts are fine lolol.
I have a 41331933770 (770) valance available to me (without AC cooling cut outs). I have an AC car --although AC is currently not working-- and I am planning to do the 770 install on my 87 with euro bumpers. Does any one know if I will have a mounting issue with the 770 valance? Based on his sale thread (see link below) it seems like e30rapidic had no issue mounting this part on his vert prior to cutting cooling holes in the valance . My questions are whether there is any known adjustment that would need to be made to fit the panel, and if I mount the valance is there a legitimate issue that would arise from not cutting the cooling holes for the AC system like e30rapidic did or could I leave it without the holes? Any insight would be immensely helpful.
and... the engine and tranny are still waiting at Metric Mechanic. I pulled my parts car motor and am working a 2.9 stroker for Cosmo.. Once that's in good shape I'm pulling callie's drivetrain, driving down to MM and picking up the new bits.
my new gig and pending move are in the middle of all this, so will be a while longer.
