I've run 23psi and its not too much, my car took it well. nothing maxed out and duty cycle was around 60% I believe. 23psi would be around 450whp on 91 octane on a good tune maybe a bit less depending on heat and losses from the supercharger.
really no point on running the turbo if your only going to run it at like 5psi. try to get that supercharge spinning slower, maybe back to m50 crank pulley? that seems easy enough, then dial up the turbo with a boost controller to get to your goal.
Your biggest problem is that the stock ignition system cant take much past 17psi(in my car not even 17psi)
if you want 23psi close up the gap and run wasted spark.
