First OFFICIAL TWINCHARGED M20 BUILD
  • Denny
    • Jan 2010
    • 822
    #256
    Originally posted by MF DOOM
    Damn you!
    LOL..Trust me I'm all :firehop: up! Car is all ready to get street tuned ...spent all day just looking at her saying damn insurance 1000000 times in my head!!
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • Denny
      • Jan 2010
      • 822
      #257
      **Update**
      Well did some part throttle tuning and thats going well... so well that I decided to get in boost a bit to start tuning the exciting part. Not so great I got this weird reaction... anybody know what this could be.??? Injectors turning off? maybe..
      and it even happened after in a no boost situation..
      f*cking weird... need some expert help :) one pattern I did find with these 2 graphs is that it happens at round 3400rpm++
      Could this be the cause? required fuel setting
      Denny
      ___________
      Blogs:
      • kamotors
        • Nov 2007
        • 7102
        #258
        does it not rev past 4045rpms?(both logs seem to stop there)
        7speedshop.com
        • Denny
          • Jan 2010
          • 822
          #259
          I didnt push the engine above 4000RPM and nothing more then 1/4 throttle on the pedal since it breaking down like that everytime I try going higher then 3500...
          Just came back from another run... and I cant rev any higher on any gear.... :(
          Denny
          ___________
          Blogs:
          • kamotors
            • Nov 2007
            • 7102
            #260
            try to reposition the CPS really close because the AFR doesnt seem to be soo terrible that it wont rev past that point
            7speedshop.com
            • Denny
              • Jan 2010
              • 822
              #261
              I checked my new log I just made and the AFR are good nothing in the 9's to make it bog or anything it really is looking like something mechanical like the CPS. I logged a session of the toothed wheel in action (under ignition log viewer) but dont understand how its read..
              Denny
              ___________
              Blogs:
              • FLG
                • Sep 2011
                • 3165
                #262
                Check the cps air gap. And if aftermarket cps get rid of it... Had nothing but issues. Finally check it with an ohm meter. Should be 540ish give or take between two of the terminals (forgot which ones but one you'll get nothing)
                Sent from my Galaxy Nexus using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • Denny
                  • Jan 2010
                  • 822
                  #263
                  Guys what should the gap space be?
                  Denny
                  ___________
                  Blogs:
                  • LJ851
                    • 7919
                    #264
                    1 mm is typical..
                    Lorin
                    The M30 is God's engine.
                    • E30stan
                      • 658
                      #265
                      why the small pics
                      • Denny
                        • Jan 2010
                        • 822
                        #266
                        Originally posted by LJ851
                        1 mm is typical..
                        It looks pretty tight right now! should it be more like paper thin..like barely touching the wheel?
                        Originally posted by E30stan
                        why the small pics
                        why because I suck at HTML :(
                        Denny
                        ___________
                        Blogs:
                        • akorcovelos
                          • Dec 2006
                          • 1149
                          #267
                          Not sure if its the same with MS2, but I was having the same issue with my MS3x and Chris gave me the solution. Start at post #36 http://www.e30tech.com/forum/showthr...=100756&page=4
                          2012 MCSCC/NSSCC CP class champ
                          HSAX Instructor
                          • Denny
                            • Jan 2010
                            • 822
                            #268
                            thank you checking this out right now..
                            Denny
                            ___________
                            Blogs:
                            • Denny
                              • Jan 2010
                              • 822
                              #269
                              You just made me realise that what if I didnt do the CPS section on my MS2 correctly! This is my first test drive with the MS2 box I built. So right now I'm going to:
                              1. Tighten the gab on the CPS
                              2. check to see if CPS sensor is good
                              3. Check my MS2 connections for the CPS
                              Going to work on it tomorrow...got to get this fixed really need to street tune before my reserved Dyno day on may 8th...
                              Denny
                              ___________
                              Blogs:
                              • LJ851
                                • 7919
                                #270
                                Denny, when i put a miller maf on my m20 on the dyno it wouldn't rev past 5k ish. Worked great with the stock chip. Ended up being an aftermarket CPS that i didn't know was on there. New OEM CPS and no more problems.
                                Lorin
