2002 + s2000 = S2002 build
  • DER E30
    • Sep 2013
    • 2343
    #136
    your car says, "Die little CV's!!! DIE!!! MUHAHAHAHAHA!"
    -Christian
    • deutschman
      • May 2008
      • 5958
      #137
      I dont think I like the flares. I would have just ordered some fiberglass pig cheek style flares. That would have saved you a lot of time and looked WAY cleaner. Just my opinion.
      I really dig the rest of the build though. Tits
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #138
        This thing is SICK why haven't I seen this thread already
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • knuklehead92
          • Aug 2011
          • 732
          #139
          In my opinion they look better in person. I would of loved the pig cheeks but my worry is that they wouldnt of fit the 255 17s. I havent see any 02 with 17 w/ pig cheeks. I also asked IE but there was a level of uncertainty and I didn't feel comfortable spending money on something that might not fit.
          Thanks!
          Trust me it stock :yawn:
          • dogze30
            #140
            those flares just dont look right
            • E30NJ
              • Aug 2013
              • 921
              #141
              The flares don't look right because it isn't painted yet. The thing is a little monster. Nice work.
              • DER E30
                • Sep 2013
                • 2343
                #142
                Can't wait to see it all done!
                -Christian
                • E30stan
                  • 658
                  #143
                  I find the fenders blend nicely with the overall silhouette of the 2002, if only there was a nice way to get ground effects around the bottom to fit. Wish you the best on getting her up and running right!
                  • lambo
                    Captain Scene Points
                    • 10953
                    #144
                    I think it needs a CSL style rear wing and front airdam.
                    • knuklehead92
                      • Aug 2011
                      • 732
                      #145
                      heres a little butt shot
                      sorry for the crappy pic quality of this one.
                      CA tuned axles should be here today, i am also swapping out the current z3m hub for a z4 hub w/ e46 rotors and calipers. This will give me an extra -23mm each side so i can tuck the wheels and go lower. My oil pan will be close to the ground but hopefully i can just raise the engine with some spacers that i will fabricate.
                      • knuklehead92
                        • Aug 2011
                        • 732
                        #146
                        getting alignment, the car feels so much better.
                        • Chinampa
                          • Jul 2013
                          • 247
                          #147
                          she looked great at autox ;) , i knew i had seen your car somewhere lol
                          - 90 325is
                          • AWDBOB
                            • Aug 2013
                            • 4393
                            #148
                            Your car hits me right in the feels
                            • knuklehead92
                              • Aug 2011
                              • 732
                              #149
                              The cars final alignment is
                              camber
                              -2.6 front
                              -2.5 rear
                              Toe 0 all around
                              I am going to buy IE offset spacers for more camber in the front. Also I want a better front coilovers and camber caster plates from Ground control for more adjustment
                              So far
                              IE offer stage 3 coil-over with race Koni insert, I think its 45mm? I think Andrew or Jeremy might correct me
                              VAC would be a custom JRZ setup 3 way
                              Ground control would be a 2 or 3 way Koni setup
                              I am also thinking about upping the spring rate to 400 rather than the 350 pound currently from IE using eibach springs
                              All these options require to send in my Tii struts.
                              The end game is this, hopefully.
                              heres a pic from auto x! Got a lot of compliments. The Car handled surprisingly well! Needs more camber in the front. and it get very twitchy as it struggles to gain traction out of an apex.
                              Other plans
                              Finish Vinyl Wrap
                              Redoing Brake system with a Tilton 3 pedal assembly
                              IE fiberglass hood, trunk, rear bumper
                              OEM dash or IE fiberglass dash
                              Recaro Pole Positions
                              Custom fab exhaust done by Ptuning in Manassas,VA
                              Roll Cage
                              Long term Goals
                              LS3 Crate engine (hopes and dreams)
                              Tube Chassis
                              • LJ851
                                • 7918
                                #150
                                Why 0 toe in the rear? Sounds unstable.
                                Lorin
                                The M30 is God's engine.
