2002 + s2000 = S2002 build
  • knuklehead92
    • Aug 2011
    • 732
    #151
    Originally posted by LJ851
    Why 0 toe in the rear? Sounds unstable.
    Just a base line to start from, any recommendation? (has e30 rear sub frame and arms)
    Trust me it stock :yawn:
    • rzerob
      • Jun 2013
      • 2315
      #152
      I liked the old thread title better. The car is looking good.
      • BoxDriver86
        • Jul 2009
        • 912
        #153
        Try .15 total toe in the front.
        If you go to a shop that has a Hunter Hawkeye Elite alignment system, they can use a program called Winalign Tuner to set up custom alignment specs including ride height and reduced bump steer. If they don't know how to use it, have them call their Hunter rep to come in and help out.
        It looks like they used a Hoffman or John Bean system to align your car. I wouldn't align a wheelbarrow with one of those.
        I just set up an '02 with an M20 for AutoX, I'll look around for the final specs on that car but I highly doubt it will work in your situation since he was still 4 lug and had a different set up. PM me if I can help.
        • LJ851
          • 7919
          #154
          I would start with 0 toe at the front. You could try toed out a little to help turn in at low speeds (autoX) but high speed straight line stability will suffer.
          In the rear i would have some toe in, maybe 1/16th on each side for a 1/8th inch total rear toe in.
          Why don't you ask in the Track and AutoX section here to see what settings others are running with success ?
          Lorin
          The M30 is God's engine.
          • F34R
            sLaughter
            • 12376
            #155
            I really feel the gas tank ruins the look of the outside, can it be raised up? or are you doing some sort of rear apron? Lots of work here, nice job.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • knuklehead92
              • Aug 2011
              • 732
              #156
              Thanks! I will try toe out in the rear.
              I will ask more questions in the track and auto x sections.
              • knuklehead92
                • Aug 2011
                • 732
                #157
                Thanks!
                I agree, looks out of place. I did raise it before the race, you can't even see it anymore. I am planning on keeping it raised. I'll post some update soon
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #158
                  If the car feels twitchy toe in will change that.
                  If the car over steers, toe in the rear, toe out for under steer. I had a problem handling an e36 on the track - pushing right through the corners. After I got the car apart, found the previous guy working on the rear set the rear to toe in max. Gave it a little toe out and it was a whole new car.
                  john@m20guru.com
                  Links:
                  • mlytle
                    • Jan 2010
                    • 50
                    #159
                    he said try toe IN for the rear, not OUT. i agree with his suggestion. every race car i set up ends up with about 1/16 in for the rear....including my M2.
                    • knuklehead92
                      • Aug 2011
                      • 732
                      #160
                      Thanks for the feed back!
                      This project is going to be on hold for a bit. I have pending job offers hopefully (fingers crossed).
                      Side note I will be picking up another 2002 this weekend! its 76! 4 speed and stock m10. The problem is, it hasnt ran since 2013. My plans are making it into a clean classy daily driver. Picked it up for $800
                      • knuklehead92
                        • Aug 2011
                        • 732
                        #161
                        current status "grassroots" enough to pass state inspection lol.....
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4504
                          #162
                          Sick hood prop is sick
                          • AbsorbantNut
                            Non faccio funzionare questa merda
                            • Jun 2010
                            • 2491
                            #163
                            This is really inspirational stuff, great work!
                            edit-with lots of different types of flares lol
                            '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                            • knuklehead92
                              • Aug 2011
                              • 732
                              #164
                              God i hated making the flares! So hard to make nice flares.
                              Thanks for the kind words man! I will be watching your build closely! Just remember in the end its all just nuts and bolts.......
                              and math......
                              • knuklehead92
                                • Aug 2011
                                • 732
                                #165
                                so I am toying with the idea of updating the front suspension to a double wishbone from a miata. This basically involves removing the stock 2002 sub frame and fabricate mounting points for the new miata sub frame.
                                This will allow me better
                                -front suspension geometry
                                -steering rack with 2.8 lock turn
                                -light suspension
                                -double wishbone with top wishbone bolted to the subframe so i am able to keep the geometry.
                                -large aftermarket support for coil overs, bbk, suspension components
                                for example
                                side note
                                this came in
                                my current setup is wilwood swinging pedals and i changing over to tiltons
                                where they sit currently
                                thoughts on miata suspension?
