2002 + s2000 = S2002 build
Last edited by knuklehead92; 07-31-2014, 10:13 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Trust me it stock :yawn: -
If you don't have luck with the junkyard I have the 318is fuel pump and complete volvo front brake kit I don't need for my project anymore. Shoot me a pm if your interested.
Also, post some info on the welder you ordered. If it truly is a straight stick welder your gonna have a hell of a time working with sheet metal. Flux core would also be tricky, but doable.
Looking good so far, Plans look solid.Comment
Stick welder is not a tool for repairing car body. What you need is MIG/MAG welder at least, and a lot of practice.Comment
lol just for fun(yes i know it backwards)
Trust me it stock :yawn:Comment
thats absurdly fuckin rusty.Comment
Yeah your going to need a MIG welder budy, or you'll be burning holes all day and make more work for your self.
Bigest lesson I learned with my last build (that I didn't get to finish) was TAKE YOUR TIME. If you try and rush anything you won't be happy with it and it will suck.
You will need to cut that trans tunnel out to fit the g260 corectly.
Do you have "6 into 2 does go?" It's very helpful.sigpic
Why not a m42 and a turbo....keeps it light up front.
And yes a stick welder isn't going to work very good for body work.... From the rust in the subframe pickup points I am guessing this is a sunroof car? Mine was worse that that...anything is fixable. Just take your timewww.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLCComment
hey guys guess i what got.....
ls1 bitches....
got it from yoshi, ecu, harness, injectors, basically everything just need to put it back together.
ill post more pics later too tired
haters guna hate!Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Good luck with that. What's the weight on that thing? What trans are you gonna use?Comment
short block around 200 pounds no heads attached, going to use t56Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Interesting, I wonder how your weight balance will be with everything in place.
Oh, make sure to add brakes and diff to the list of stuff to replace. With an LS1 the 'volvo' vented upgrade won't cut it, and you'll be blowing up the stock diff with that torque like it's a joke.Comment
lol i know.. i will be getting brakes from massive, and going to use tii struts. aLast edited by knuklehead92; 07-31-2014, 10:14 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
well i talked to ak sportscars, they make a adapter kit for the ls1 to use the getrag 260. i might go this route to keep the weight down, cheap, easier to fit.
the kit comes with the adapter plate , a centralizing disc , a bearing for the crank and a sleeve for the clutch bearing. they told me all i need is the transmission, ls3 flywheel, ls3 clutch, and starter for it to workYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
