2002 + s2000 = S2002 build
  • lambo
    Captain Scene Points
    • 10953
    #166
    Originally posted by knuklehead92
    thoughts on miata suspension?
    crazy
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      #167
      this needs to be given a new chassis code, its only 27% actual 2002 now
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • SkiFree
        • Jun 2011
        • 2766
        #168
        If it was anyone else I'd say go stick your head in the sand for a while. But, you do have a knack for pulling off the obnoxious pretty well.
        However, if you do decide to go this route, I cannot emphasize enough the importance of using suspension software to calculate your points. If you do not, or are even a bit off (during one of those "eh" moments) then any gain you may have had will be thrown out the window. I know of more than one car that made magazines with "x-subframe/suspension swapped in" that weren't anything more than rolling sculptures.
        ADAMS Autosport
        • knuklehead92
          • Aug 2011
          • 732
          #169
          welp, scratch the miata.....
          Just bought a rear ended s2000..... with no frame damage and suspension in perfect condition.....
          Time to swap chassis's lol
          2002 body on s2k chassis WhAT??!?!?!?!?!?!?
          Trust me it stock :yawn:
          • DER E30
            • Sep 2013
            • 2349
            #170
            Sounds like winning! S2k motor too?
            -Christian
            • lambo
              • 10953
              #171
              double crazy
              • ForcedFirebird
                • Feb 2007
                • 8300
                #172
                What is this? An s20002002tiiM2+2?
                john@m20guru.com
                Links:
                • mr2peak
                  • 2388
                  #173
                  You should seriously just design a tube-frame to drape the 2002 body over. Go look at the Lotus 7 build books and locostusa.com for some help and inspiration.
                  Drive it hard. Maintain it well.
                  A Topless Memorandum
                  • SkiFree
                    • Jun 2011
                    • 2766
                    #174
                    Originally posted by ForcedFirebird
                    s20002002tiiM2+2
                    If this badge is printed and mounted on your car when finished, it .... would ... be .... awesome! You then must bring it to Monterey and show it out at the Legends Concours.
                    ADAMS Autosport
                    • Joe G
                      • 2942
                      #175
                      Just read this start to finish. Great build, looking forward to whatever comes next.
                      Current Car: 2011 BMW 135i, M-Sport, 6 speed
                      Originally posted by lambo
                      Sounds like you need a massage.
                      Originally posted by kpeng
                      Who the hell is Vlad?
                      • knuklehead92
                        • Aug 2011
                        • 732
                        #176
                        I will be picking up the S2000 chassis this friday.
                        Currently my plan is disassemble the 2002 and sell remaining parts I don't need.
                        My s52 is pending a sale, if it falls through I will stick with the power plant. If not then f20c route then later turbo.
                        If stick with the s52, later I will go s54 depening how the s2000 chassis layout will be.
                        My plan push the s52 lump far back as possible (if dont sell the s52). These are assumptions here.
                        Car plans
                        -r200 differential kit or ford 8.8 (i cant decide)
                        Why change the rear diff? Because its notoriously weak.
                        -Stoptech bbk front
                        -Wedsports tc105n wheels 17x9 255 square setup
                        -Ohlins dfv coilovers
                        • rturbo 930
                          • Dec 2005
                          • 2621
                          #177
                          You want the Ford 8.8. The diff itself is cheap and plentiful. LSD options are available, and there's lots of gear sets to choose from in different ratios for not much money.
                          The R200, not so much, which is why Z guys (which came with an R180 or R200) are starting to move over to the Ford 8.8. The 8.8 setup is also lighter than an R200 by about 15lbs, give or take, and it's stronger too - the R200 output shafts (long nose, at least), are a weak point if you're making big power.
                          • knuklehead92
                            • Aug 2011
                            • 732
                            #178
                            thanks for insight!
                            Ford 8.8 it is!! the only problem I have to get an irs pumpkin. And the search continues...
                            Also f20c weight is 326lbs and s52 is 436lbs
                            Thats not too bad...
                            • barbierij
                              • Sep 2012
                              • 1294
                              #179
                              Too bad you weren't closer. I have a ford 8.8 with 3.55 that needs a rebuild (pinion is chewed up).
                              FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
                              Saab/GM tech2 programming
                              My for sale thread
                              1990 325iX for sale or part out
                              Did you buy something from me? Please leave feedback!
                              Originally posted by K20RI_211
                              And I have to ask if you make a hobby out of thread-bombing with retarded questions?
                              • knuklehead92
                                • Aug 2011
                                • 732
                                #180
                                Pmed
