2002 + s2000 = S2002 build
  • knuklehead92
    • Aug 2011
    • 732
    #46
    did some work today enjoy!
    driver side floorpan since the old is is bad and frame rail completely rusted
    coilovers installed
    took out the s52 today going to clean it up paint, re gasket it
    fabed up a new floorpan
    driver side
    i am going to try to finish the driver side tomorrow and drop the front subframe for a complete refresh and clean the engine bay.
    Trust me it stock :yawn:
    • knuklehead92
      • Aug 2011
      • 732
      #47
      finished the driver floor going to do the passenger the same way
      • e30lov
        • Jul 2008
        • 1597
        #48
        your typing skills make my head hurt, but you have done some great work so far. Keep it up man
        `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
        • knuklehead92
          • Aug 2011
          • 732
          #49
          more pics from today :D
          wire brushed with before and after
          boxed in control arms and seam welded
          refreshed the whole front sub frame
          i used ireland engineering poly bushings for everything on this car so far, thanks again Ireland engineering :D
          I also started to clean the engine bay and start the shaving process XD, i will post pics later im pooped :yawn:
          • deutschman
            • May 2008
            • 5958
            #50
            Nice clean work and good looking welds.
            • tinkwithanr
              • Jun 2010
              • 377
              #51
              Nice progress. This thread is like deja vu for me lol.
              Tinker Engineering - 2014
              Mica - 2000 BMW 323i - The one that started it all
              Fiona - 1975 BMW 2002 - The Definition of Project Creep
              Heidi - 1988 BMW M5 - The piece of BMW history
              Silvia - 2013 Subaru WRX - Stock, for now
              • knuklehead92
                • Aug 2011
                • 732
                #52
                haha, your build is that motivating :D
                how is your build coming along? i hope its almost done!
                • knuklehead92
                  • Aug 2011
                  • 732
                  #53
                  started working on the s52
                  clean inside
                  dirty pistons but clean bores
                  head is off
                  cleaned the pistons and the deck
                  wrinkle engine cover
                  New water pump
                  new housing
                  painted the block, came out okay :)
                  VAC Oil pan baffle for autox and track
                  oem headgasket and other goodies
                  stay tuned for this weekend ;)
                  • sweet6e30
                    • Feb 2011
                    • 531
                    #54
                    holy shitskies,... where the fak is the "LIKE" button.......
                    Some serious Carnage going on here,.NICE WORK!
                    my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                    • buguhrich
                      • Nov 2008
                      • 141
                      #55
                      Originally posted by knuklehead92
                      my awesome 16 guage galvinized hot dipped steel sheet metal for rust repair
                      You're holding your breath while you weld that galvanized steel right? haha
                      • broach328
                        • Nov 2009
                        • 296
                        #56
                        This is epic. Should be nice and terrifying to drive. As I am sure youve heard before, turn left to go right :p
                        • JCarp90
                          • Feb 2011
                          • 1759
                          #57
                          You have my attention.
                          • knuklehead92
                            • Aug 2011
                            • 732
                            #58
                            its been while since i updated this i will show where i am at
                            i already re-gasketed the s52, timing cover, headgasket ect whole nine with oem parts from bluntech.
                            after doing the engine i finished the engine bay by grinding it down and brushing on this special clear coat design to protect metal but give it that bare metal look. it looks great!
                            when the engine bay was done i decide to drop in the engine and try to start it. I got everything in and pluged up but only thing from keeping to start it is spark plugs and connecting the fuel pump up. other than that it cranks and i can hear the icv huming so that means its good soooo far.... lol i will find out soon :)
                            onto the pics
                            modified firewall
                            e39 m5 cyclone separator, supposedly a lot better than the stock separator
                            stuff i used for the bare metal look, i brushed it on and left no streaks, awesome product
                            oil pan clearance :( and its not even fully lowered
                            not much clearance for the boot heheh
                            bare metal finish
                            more bare metal finish
                            in all her glory
                            used mini cooper belt
                            inside
                            going to buy spark plugs and hook up the fuel lines and we shall see what happens :) cross fingers!!!! hahhhhah *screaming like a lil bitch*
                            as far as plugging up the s52 ODB2 into a 2002
                            x20 bmw 2002 harness
                            alt 25 > blue wire that is in the voltage reg
                            ignition 21 > green wire inside the firewall or the green wire behind the ignition starter
                            starter 15 > ground
                            starter 18 > pin 50 behind the ignition starter
                            fuel pump 13 > direct to fuel pump i am using a 318is from a e30 with pick up
                            and it should work, with this done i have the icv hum and crank. i just need to plop in some spark plugs and give it gas and it should be on like bing bong jack!
                            hopefully people can take advantage of odb2 and not convert to odb1 which is stupid, only gain you get is odb 1 intake manifold other wise a down grade
                            these are what i used for hooking the s52 up
                            odb2 x20
                            ms41.1 dme pin out
                            the rest is easy and hooking up gauges to the x20 or whatever your using
                            i am using a ms41.1 ecu odb2 from DesertBMW ews delete, tune rear o2 delete and much more
                            • knuklehead92
                              • Aug 2011
                              • 732
                              #59
                              offcourse!! :D
                              • knuklehead92
                                • Aug 2011
                                • 732
                                #60
                                i got it started guys!!!! loud as crap!!!!! im so siked to get this on the road and drive!!! i will provide video later!
