TR-42 build. Non e30 content. Subaru powered.
  • IronFreak
    • Dec 2012
    • 3702
    #196
    Is this a tach from a motorcycle?
    Instagram @rebellionforge
    • jaywood
      • Jul 2010
      • 4528
      #197
      Yes. This one has a 10k max RPM but they make the same model w/ a 20k RPM
      • JCarp90
        • Feb 2011
        • 1759
        #198
        Originally posted by jaywood
        Seriously, it is a GREAT investment
        Thanks man. I'll get some vids up as soon as it starts!
        What's your timeline for having this thing running?
        • jaywood
          • Jul 2010
          • 4528
          #199
          A few months probably....
          In order for this thing to be running we need to do the following:
          Finish engine setup -- 1000cc injectors, Grimmspeed uppipe, turbo-back exhaust, turbo/wastegate, intercooler & piping, wiring harness, ECU mounting & tuning.
          Chassis wiring -- battery, headlights, turn signals, brake lights, horns, gauges, cluster.
          And than it's exterior/interior time -- body work, paint, leather wrap, etc.
          • IronFreak
            • Dec 2012
            • 3702
            #200
            It reminds me of the one I had on my RC51. Is this a kit you can buy with all the sensors or did you pull it off a bike? Just curious how it reads out, magnet based like a lot of them?
            • Vtec?lol
              • Dec 2009
              • 3278
              #201
              Good work!
              I have the same craftsman 1/2" impact. With the Extended XCP lithium battery you can get that sum'bitch to whip out about 350-375 lbs loosening.
              Keep it up!
              • jaywood
                • Jul 2010
                • 4528
                #202
                Thanks guys!
                This weekend we got some stuff done. Car cover built and extended 17" taller (Harbor Frieght purchase) to clear the doors. Coolant hoses are all routed. VDO gauges ordered. AEM eugo wideband ordered. 4 point harnesses ordered. Intercooler is being figured out. We are going to be using a top mount air-water IC from frozenboost. We are trying to figure out the best size heat exchanger for how much room we have (or don't have)
                • jaywood
                  • Jul 2010
                  • 4528
                  #203
                  Trying out flickr...guess they have unlimited monthly bandwidth.
                  Here's some pics of the gas tank filler neck thing. Still learning how to weld the aluminum!
                  gas tank tacked by namesdutt, on Flickr
                  gas tank welded by namesdutt, on Flickr
                  • lambo
                    Captain Scene Points
                    • 10953
                    #204
                    Haha! I love the Hella supertones!
                    • jaywood
                      • Jul 2010
                      • 4528
                      #205
                      All of the Subaru guys do it, we're just following the crowd!
                      • jaywood
                        • Jul 2010
                        • 4528
                        #206
                        And here's a pic of me I took for the photography class I just started
                        TIG Portrait by Jeff States, on Flickr
                        • andyman2487
                          • Apr 2007
                          • 361
                          #207
                          Awesome project man, looks great! That thing is going to be an animal.
                          Those welds look fine! Our welder at work has been TIGing for like 30 years and his beads look about the same as yours. It's all about surface prep and getting adequate penetration which it looks like you did.
                          Keep up the good work!
                          • JCarp90
                            • Feb 2011
                            • 1759
                            #208
                            My feels every time you update this thread.
                            • jaywood
                              • Jul 2010
                              • 4528
                              #209
                              Got a few updates (small ones)
                              Tank reinstalled w/ new filler
                              Fuel Safe by Jeff States, on Flickr
                              Misc coolant tubes
                              Coolant tubes -- Center Tunnel by Jeff States, on Flickr
                              Coolant tubes -- center tunnel --> engine by Jeff States, on Flickr
                              • jaywood
                                • Jul 2010
                                • 4528
                                #210
                                Got some stuff done over the weekend. Gas filler door partly mounted -- still need bolts/nuts. The ones that came with it were too short.
                                We are running a frozenboost water/air intercooler setup. Heat exchanger is mounted in front of the radiator. Intercooler is a type 14. Pump is the 401FC type. Pics:
                                Gas Filler Door - closed and locked by Jeff States, on Flickr
                                Gas Filler Door - open by Jeff States, on Flickr
                                Intercooler setup
                                Air/Water intercooler setup by Jeff States, on Flickr
                                Heat Exchanger for A/W Intercooler by Jeff States, on Flickr
                                Gauges ------ AEM wideband. VDO: boost, oil pressure, coolant temp, ammeter, voltmeter
                                VDO Gauges by Jeff States, on Flickr
