TR-42 build. Non e30 content. Subaru powered.
  • Eric
    • 5139
    #181
    Originally posted by jaywood
    The bolt pattern that came with the car has very poor aftermarket wheel selection.
    CCW, kodiak and others can make a wheel in any bolt pattern and smaller sizes. I wonder what the price difference between the EC-7's. those uber expensive R888's, and adapters cost compared to a smaller wheel/tire package.
    Plus, the skinny wheels on the Atom just look kinda
    Maybe a stanced E36 would be a better build?
    In all honesty, there is a reason you don't see lotus's (loti?) at the track with big fat wheels. A big heavy E36 works well with 285/30/18's, but drop 1500lbs and it doesn't need that much tire to go fast. I'd suspect that 255's would perform just as well as those 315's!
    If lap times weren't any different, the smaller wheels/tires will feel lighter/nimbler (whole reason for building this thing over a normal car right?) .
    • jaywood
      • Jul 2010
      • 4528
      #182
      Originally posted by deutschman
      Maybe later on down the road you can get a company like Rotiform to make you a set of custom forged racing wheels. They can make any bolt pattern, offset, and size. Its pricy but they are beautiful and will fit the car perfectly.
      Fifteen52 also makes wheels to custom sizes and their wheels look a bit more business like and less show car like.
      http://fifteen52.us/shop-2/#!/~/cate...=0&sort=normal
      We looked into CCW's before we decided on the Apex's. Fifteen52 has some nice selection as well...thanks.
      Good suggestions. However, this car is just built for fun. Nothing about it is practical. We aren't building it to set track records. My dad is going after a certain look--beefy tires/wheels. I'm all for it! I think it looks great :p
      Maybe down the road if we do get serious into tracking it we will look at alternate wheel/tire selections that will better suit the nimbleness/lightness of this kart.
      • Eric
        • 5139
        #183
        Makes perfect sense. Carry on with the awesome!:crazy:
        • jaywood
          • Jul 2010
          • 4528
          #184
          Got some updates over the past few weekends. We have been out of town so not much has gotten done but here's some pics for you guys
          Got an alternator and cleaned it up a bit. Powdercoated the brackets that came off of our spare EJ20 engine wrinkle red. Turned out very nice
          I built a locking glove box. It turned out pretty nice. We will be leather/foam wrapping it so it will have some cushion to it.. First time welding 3/16" aluminum. Still learning!
          The hinge in the rear is a piano style hinge
          It isn't aligned yet. We need some brackets that hold it in place but this is where the lock is placed. The screws will be ground down flush.
          Mounted the e-brake. Came out a Miata.
          We also made began the aluminum cover for the shift linkage/etc. Making a shift boot will be next.
          Built a bracket and sewed up a velcro strap for the race battery. We'll see how it holds up. Also mounted the fuse box. (fist picture taken in passenger seat to give you an idea of where it is)
          Also got some license plate bolts......
          Built in plate lights!
          We also got the headlights mounted and the front mirrors/turn signals mounted. I forgot to snap some pics but I'll try and get some this week!
          • acolella76
            • 2950
            #185
            That license plate bolt is pretty trick!
            -Alex
            • jaywood
              • Jul 2010
              • 4528
              #186
              Thanks! :p
              • lambo
                Captain Scene Points
                • 10953
                #187
                How do you ensure the bolts are both tight and aligned properly to illuminate the plate?
                • 96E36
                  • Feb 2013
                  • 4
                  #188
                  If this amazing build continues..
                  Originally posted by Van Westervelt
                  Progress is being made, but it's the equivalent of pulling a full mouth of teeth while inebriated, half blind, arthritic, and using needle nose pliers from harbor freight that are 10 years old.
                  • jaywood
                    • Jul 2010
                    • 4528
                    #189
                    It doesn't thread into the frame. There is a plastic nut that keeps everything tight
                    • rzerob
                      • Jun 2013
                      • 2315
                      #190
                      Subscribed. This is awesome.
                      • jaywood
                        • Jul 2010
                        • 4528
                        #191
                        Finished the parking brake today. Made some of these clamps for the cable.
                        Cable at the e-brake handle
                        Here's how the cable attaches to the caliper
                        Pic of linkage
                        Cluster is mounted.
                        Driver seat view
                        And here's a box of.....????
                        Engine harness.....
                        • Link
                          • May 2012
                          • 834
                          #192
                          Wow. Sub'd.
                          View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
                          • jaywood
                            • Jul 2010
                            • 4528
                            #193
                            Mounted the STI pedal. The engine/throttle body is DBW so we had to get the DBW pedal.
                            Headlight brackets
                            Here's how the headlights look...hood on, hood off
                            And also started tearing into the harness
                            BTW, this is our most used tool. It is amazing.
                            • JCarp90
                              • Feb 2011
                              • 1759
                              #194
                              I have the same impact and love it. Everybody needs one of those.
                              Great work as always. Can't wait to see videos of this thing in action.
                              • jaywood
                                • Jul 2010
                                • 4528
                                #195
                                Seriously, it is a GREAT investment
                                Thanks man. I'll get some vids up as soon as it starts!
