There aren't really any pics to add at this point since there is nothing new in pulling a vac and charging the system so from here on, its pure art & science. After filling the pump with oil and connecting it via the yellow hose it spat out a healthy wisp of white smoke within the first few seconds. The gauge also shot to -30 just as quickly. Obviously this did not meet the standard for "deep vacuum" so I let it run for an hour then turned it off.
The big question at this stage was if it would hold the vacuum so I let it sit for another hour..and damn if the gauge did not move. Thank you Nylog Blue !!
The 2 main ways to charge are by weight and pressure. Pressure requires way more finesse as the variables are ambient temp, humidity, compressor speed and I will get to more on this later. Weight is weight, so I pulled out my digital scale again. The full cans weigh exactly 1 lb (454.4 grams) and hold 12 oz of refrigerant. Add 90.3 grams for the valve since I knew that last partial can would have to be weighed with it. BMW calls for 900g of r134a +/- 25g. Basically, 31.5 ounces which is bang on the often quoted 10% reduction from the 35oz r12 charge. Keep in mind that these specs are for a converted system using the stock compressor which has either had the seals swapped or was installed w r134a compatible seals. Either way, those compressors were designed to run on r12. more on that later.
I found at that its best to not to fully open the valve on the can as it will freeze even when you set it in a bowl of fairly warm water. Patience was the order of the day. I went through 925g of refrigerant and given that I burped the gauge end of the yellow hose every time I changed cans to clear out any air, I figured I was right where I needed to be. When the pressure in the system equaled can pressure I started the car so it would pull in the rest and the good news at this point is that the compressor engaged and the gauges noticed.
