E36 M3 - LS3/TR6060 Swap
  • ACHTUNG
    • May 2005
    • 2397
    #181
    Jake of all trades! Nothing you can't do...
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
    • 2e30
      • Jul 2008
      • 277
      #182
      great work
      my e30 trailer build thread http://www.e30tech.com/forum/showthread.php?t=68391
      TRAILER PROJECT 85% COMPLETE
      SPORTMAXXES CAN LOOK OK
      • BamaE30
        • 239
        #183
        Happy Birthday Jake.....
        Imported from Detroit
        • jakeb
          • 1909
          #184
          thanks guys!
          Lots of little tacks...I go around each flare. Let it cool for a bit and do it again. To keep any warpage to a minimum.
          Fronts still need more
          www.classicdaily.net
          1970 m42 swapped 2002
          1985 LS1/T56 Swapped e28 (557e)
          www.blunttech.com - For all your parts needs
          Follow me on Instagram for constant build updates @classicdaily
          https://www.facebook.com/ClassicDailyLLC
          • jakeb
            • 1909
            #185
            I left part of the inner fender and then will bend it out to match the new flare. Either weld or use panel adhesive to hold the two layers together.
            Picture isn't very good as the flash on the camera went off and picked up all the dust, etc
            All the welds around ground down
              • 37832
              #186
              Sweet!
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • jakeb
                • 1909
                #187
                I was away for the weekend but back at it today.
                Camaro front driveshaft section showed up....going to have this combined with the BMW shaft.
                BMW bottom...Camaro top
                I would say these are pretty close....
                Camaro
                BMW
                Front section
                Rear section
                More updates later
                • jakeb
                  • 1909
                  #188
                  First coat of filler (duraglass) going on the flares
                  Cruise control actuator is being removed because it is a Drive by wire throttle body. Brackets are coming off too...holes will be welded up and then the entire bay will get repainted.
                  • mcr_driver
                    • 4491
                    #189
                    It's always nice to come in to this thread with updates, beast is look nice i am liking the flares. I forgot why'd you with e46 non-m flares? was that all you needed or were those the one's that best matched up with the e36 body lines as opposed to e46M.
                    • jakeb
                      • 1909
                      #190
                      e46 m3 fenders are something like $700ea...new. These were around $300 shipped for 4 fenders.
                      • jakeb
                        • 1909
                        #191
                        Another mid day update...
                        Engine is back out:
                        ABS pump location
                        ABS pump brackets
                        Engine bay getting ready for some fresh paint
                        pulled the old hood liner
                        More flare work
                        • ACHTUNG
                          • May 2005
                          • 2397
                          #192
                          I love the smell of duraglass.
                          • george graves
                            • 19998
                            #193
                            Noobie body work question....but how do you sculpt an inside corner like that? (that must be one of the more challenging type of thing to sculpt?!?!)
                            Originally posted by Matt-B
                            • jakeb
                              • 1909
                              #194
                              Just let up on the spatula a little... Just need enough filler here to cover the weld. Then it will get some finer stuff on top to make it all smooth.
                              • jakeb
                                • 1909
                                #195
                                Brake lines to ABS pump all extended...and off to powder coat
                                Jigged the trans mount before going off to powder coat
                                Engine mounts are off to be coated as well and then they will get jigged...the powder coater I use also does Lathe work and he is making me a plug to make the engine mount jig.
                                Passenger side header jigged and ready to weld
                                header off...
                                Drivers side
                                Both together...Once the headers are all welded up I will add a locator for the vband and collector
