E36 M3 - LS3/TR6060 Swap
    • 37832
    #241
    Very nice progress!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Nick_S
      • Apr 2011
      • 3658
      #242
      Incredible craftsmanship. You're an artist.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • jakeb
        • 1909
        #243
        thanks guys!
        Was hoping to fire it today but with the temps at 95 and 85 in the shop it's hard to work very fast...either way still progress.
        All the brakes/lines/etc are all hooked up. And more flare work.
        Shifter in
        Shifter linkage
        Under car pictures...just because everyone likes pictures.
        How the AC compressor came out...you can also see the trans cooler lines in there and the battery cable.
        www.classicdaily.net
        1970 m42 swapped 2002
        1985 LS1/T56 Swapped e28 (557e)
        www.blunttech.com - For all your parts needs
        Follow me on Instagram for constant build updates @classicdaily
        https://www.facebook.com/ClassicDailyLLC
        • jakeb
          • 1909
          #244
          Not fired yet...waiting on intake pipe. The one I had was a bit too big to fit. It's ordered and in route...very very very soon!
          Exhaust all bolted up, heat shield on, driveshaft in, etc
          Suspension is all tightened up...
          Set it down on the ground.
          Front nose isn't tightened.
          Will be wiring the LSx harness into the BMW x20 tomorrow and will power everything up to program the PCM.
          • giantkeeper
            • Aug 2009
            • 1416
            #245
            Holy giant tires
            Always Always go for the reach around if there is an option
              • 37832
              #246
              Getting close!
              Are you happy with the fit of the suspension/wheel/tire/fender combo?
              Grover Beach, CA
              www.BimmerHeads.com
              • JCarp90
                • Feb 2011
                • 1759
                #247
                Dem tyres
                • Myster-E
                  Performance
                  • 552
                  #248
                  Awesome build!
                  1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
                  Visit www.BimmerHeads.com for all of your 12 valve needs!
                  • kalib0y
                    • Dec 2004
                    • 3620
                    #249
                    Awesome Awesome work! so clean. DO you have any pic of how your driver side headers dodge the steering shaft?
                    You make me want to switch over to your kit. :)
                    95 7.1L 16V E36 M3
                    Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                    LIKE my Facebook Page! CLICK HERE
                    • jakeb
                      • 1909
                      #250
                      thanks guys!
                      It's hard to get a pic of the headers around the steering as it's hard to have the camera focus. I'll see what I can do tho.
                      I used a PSI harness on this one. Connecting everything to the BMW x20.
                      From above
                      Reading the PCM
                      Trans cooler just showed up. It will go about here.
                      • Vtec?lol
                        • Dec 2009
                        • 3278
                        #251
                        lol... You've gotta be kidding?
                        Down here garage temps reach 105-110 easy. I need to move to michigan!
                        • jakeb
                          • 1909
                          #252
                          Running wires to the gas pedal. Through the pocket where the PCM will live above the glove box.
                          While I had the glove box all apart I replaced the cabin filter....man they get dirty.
                          New one in and vacuumed the box all out. Much Better
                          Made a bracket for the gas pedal
                          Angle iron piece is welded to the firewall and tapped to bolt the flat piece that the pedal is bolted to.
                          Pedal is about the same spot as the stock one. Feels really good.
                          Trans cooler..still need to finish the bracket...just weld with vise grips here.
                          The plan was to have it running today but the intake pipe showed up at the end of the day and didn't have time to finish it.
                          It has to be extended a little bit at the throttle body.
                          The LS3 uses a cassette style MAF and a little flange has to be welded to an aluminum intake pipe.
                          The flange
                          I am not comfortable welding aluminum yet (to the quality I like) so I will have to take it to a local welding shop to weld up.
                            • 37832
                            #253
                            I apologize if it's been covered but why did you decide to keep the drive by wire? There are cable conversion options for the LS engines right?
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • jakeb
                              • 1909
                              #254
                              Yes there are conversions to DBC but then you need a new throttle body, IAC, TPS, the wiring to go to the CM, and the engine would have to be retuned. So mostly for ease, cost, and it's nice to keep things OEM. (engine wise)
                                • 37832
                                #255
                                Totally understand on that one! Was just curious the reasoning and I appreciate the info. :)
                                Grover Beach, CA
                                www.BimmerHeads.com
