E36 M3 - LS3/TR6060 Swap
  • Hurricane
    • Jul 2013
    • 3
    #211
    Great project Jake, top notch work in this thread!
    I also spent most of my morning drooling and dreaming.
    And I have the same birthday! :)
    I was wondering if you could PM or post more information on your TIG welder!
    Thanks
    Dustin
    • jakeb
      • 1909
      #212
      Thanks
      Dustin
      haha, awesome on the matching birthday. PM incoming
      www.classicdaily.net
      1970 m42 swapped 2002
      1985 LS1/T56 Swapped e28 (557e)
      www.blunttech.com - For all your parts needs
      Follow me on Instagram for constant build updates @classicdaily
      https://www.facebook.com/ClassicDailyLLC
      • jakeb
        • 1909
        #213
        Welding the Vbands to the collectors
        Showing the bead
        Headers just about done...just need to weld the collectors on. That might wait until they are back in the car so I can get the angle I want.
        Merge Bullet on the drivers side
        Put the front calipers all back together
        • IronFreak
          • Dec 2012
          • 3702
          #214
          What is the significance of the merge bullet, eliminate the possibility of pressure entering a different port?
          Instagram @rebellionforge
          • mcr_driver
            • 4491
            #215
            I would imagine for the back pressure and flow. Rather then all 4 hitting eachother and bouncing off eachother they flow in to eachother down the pipe.
            • jakeb
              • 1909
              #216
              Yeah it helps them all flow and merge together. Also it would be fairly impossible to weld on the inside where the 4 runners come together. You can also use a little cross looking thing but the merge bullet is better.
              • jakeb
                • 1909
                #217
                Long weekend away at tedfest vintage BMW show near Toronto. Back at the e36...hoping to have it running early next week. Getting very close!
                Headers on the engine so I can get the collectors in just the right spot.
                Engine back in the car to figure out collectors...forgot to get a pic with the collectors on there.
                Drivers side header all welded up and ready to go
                Swapped to a new oil pan rather than my mock up pan
                New windage tray and oil pickup
                Jigging the mounts
                Jigging the shifter carrier
                This isn't a very good picture but I really like how stock everything is looking.
                • giantkeeper
                  • Aug 2009
                  • 1416
                  #218
                  Those headers look pretty damn good man! Great stuff!
                  Always Always go for the reach around if there is an option
                    • 37829
                    #219
                    What did it cost you in materials to build a (amazing) set of headers like that? I know the skill and labor is the valuable part but just curious...
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • jakeb
                      • 1909
                      #220
                      Materials were in the $500 range for stainless
                      • jakeb
                        • 1909
                        #221
                        Headers are FULLY welded now.
                        Simple little power steering line made
                        Fitting at the rack
                        Guess I didn't get a pic of the fitting at the pump.
                        Oil PSI sensor
                        Driveshaft showed up...m3 rear section, camaro front section, new ujoints, etc etc
                        All the exhaust supplies...minus the tubing. All stainless
                          • 37829
                          #222
                          Not bad at all!
                          What kind of muffler is the non-Magnaflow in your pic above?
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • kalib0y
                            • Dec 2004
                            • 3620
                            #223
                            looks like a Spintech. I am actually going to them to have a custom muffler made to calm down my exhaust because my old ears can't take the rumble lol
                            95 7.1L 16V E36 M3
                            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                            LIKE my Facebook Page! CLICK HERE
                            • Nick_S
                              • Apr 2011
                              • 3655
                              #224
                              Unbelievable build. Your skills are top notch.
                              91 318is M50 swapped
                              05 Honda Pilot
                              24V swap thread
                              • jakeb
                                • 1909
                                #225
                                Yup it is a spintech, they are awesome!
                                thanks...sometimes I even surprise myself.
