95maxrider's Rally-x '88 E28 build- caged, head swap and more
  • 95maxrider
    • Oct 2012
    • 393
    #286
    Sometimes, smelling gas fumes can be quite enjoyable. But not inside your car. The car has smelled of gas to some extent for quite some time, and it got worse when the tank was full. It wasn't until a few races ago that we saw gas on our mudflap after runs, and we knew we had to do something. I had a feeling we were going to find rust when we dropped the tank, so I bought a bunch of awesome supplies. Restoration appeared to be the only option, as new tanks were all $600-$800.
    Let's see what we've got going on...
    The tank would have been much harder to remove due to a rounded/rusted off bolt had it not been for these awesome tools
    It took a while to get all of the baked on dirt off, but here's what it looks like bare.
    WTF? This isn't rust!?!
    This is what really scared me, since this is the side that faces the exhaust.
    I envisioned spending a few days restoring the tank, as products would need time to cure, and not really looking forward to it. I decided I should check again for a new one. The first link I click on was ECS Tuning, and lo and behold, they were having a blowout sale for $275. Sold.
    Time was running out before the next event, and the only day Bobby and I could get together was the day before the race. Naturally, disaster ensued. It freaking rained so hard that the tent wanted to collapse and I had to keep pushing the water out. My cardboard work mat was destroyed. We were lying in a muddy stream of water under a dirty car working with fuel lines. Doesn't get much better than this.
    While working under the car I noticed a fuel line that felt damaged. Sure enough:
    So we fixed that. Then we had to improvise for the heat shield as the holes on the new tank didn't line up with one heat shield hole.
    We got everything buttoned up, and the car started right up! We checked for leaks all over and didn't see a drop. Hooray! A few hours later I decided to go fill up the gas tank, as I had only put about 2 gallons in from its old supply. I filled up the car and decided on a whim to check the access hole in the trunk to the top of the in tank pump for any leaks. Oh crap. It's a pool of fuel. No amount of massive wads of paper towels from the dispenser would absorb it or stop it. I stepped back in terror to assess the situation, from a distance, where I noticed a steady drip of fuel from the tank to the ground. This is going to get worse before it gets better.
    I had my wife bring me my hand pump thingy and an empty fuel tank to drain off some of the tank. After taking some out I could see that the leak was from all around the in tank pump as well as the level sensor unit. When I disassembled my old tank and the pump, there was no gasket, which surprised me a little, but I figured BMW knew something I didn't. I also didn't see one for the level sensor. Upon further inspection of RealOEM we figured out that yes, there are definitely gaskets in there. Double crap. It's 5 pm on a Saturday afternoon, and no dealerships are open. I start calling around for parts stores with rolls of cork gasket material, but everyone says no. Upon my next trip to the local store, I quickly find the stuff and shake my head. Back at the gas station, I walk across the street to the hardware store and find some gooey fuel-safe gasket maker stuff that I can't remember the name of, but people said it works. My wife then brings me my hand tools and Bobby arrives to lend a hand. We get the goo installed, which had rather vague instructions for cure time, but they seemed short. We felt like 45 minutes was more than enough and I drove it home with Bobby following in his car. Turns out I was spewing fuel the whole way, but hey, I can't leave the car in the gas station parking lot overnight. Thankfully, I made it home safely around 9. I had been at that gas station for about 4 hours! It was then that I called it quits for the night, and started looking for another car to drive the next day. Cue Rally-x #6 review post, one post above this one!
    So it turns out we did have the gasket for the level sensor, it was just totally smushed and hidden. But no gasket for the pump.
    I felt much better about everything when the new gasket for the pump arrived!
    And while we were at it, we replaced the gasket for the fuel cap. It fit tighter after replacement!
    FINALLY, everything goes back together, and actually stays sealed after being filled up and beat on! And for the first time in a long time, there are zero fuel smells around and in the car! I was also very happy to have my 1/4" torque wrench, as the nuts and bolts have very specific, and very low, torque settings for the pump and level sensor.
    ________________________1988 528e Rally-xmobile___________________
    2014 WDCR Rally-X MR Season Champion, 2014 NE Div. Challenge MR Winner
    • TeXJ
      • 1914
      #287
      Found it!
      1990 325is
      m52b28
      3.73lsd
      g260 (1987 325is 5spd tranny)
      • 95maxrider
        • Oct 2012
        • 393
        #288
        Originally posted by TeXJ
        Found it!
        Found what?
        • stonea
          • 2890
          #289
          He responded to the wrong thread
          Sent from my SM-G920V using Tapatalk
          My Garage
          Feedback
          Instagram: Stone.Hopkins
          • 95maxrider
            • Oct 2012
            • 393
            #290
            Well at this point there is no point in updating this thread, but dammit, I'm gonna finish what I started.
            First things first, we had to secure this battery. The rubber tie down seemed to be working okay, but I still noticed some play in the battery, so I wanted something really secure. Enter two tie down kits:
            And some hose to ensure a tight fit
            And just like that, we had the most secure battery of all the rally cars!
            Next up were some little things in the engine bay. I've been chasing down a rough idle ever since we bought the car, but no matter what I did, it was still there. One day while poking around I decided to check out the vacuum hose that goes from the valve cover to the throttle body under the IM. Turns out 30 years of heat can turn rubber into plastic, and plastic doesn't conform to other shapes very well. Ours was so hard that I snapped it in two pieces!
            No bueno
            Muy bueno
            I also found a broken hose clamp on the return fuel line coming off the rail. I poked the hose and fuel came out. Again, not really a good thing. A new fuel hose clamp later and we were in business!
            And guess what?? The car actually had a smooth idle for the first time in 3+ years! Vacuum leaks be gone! It felt so good to not have the car rocking and shaking at idle, I just couldn't believe it.
            Back to the gas tank: All the nuts and bolts that held things together were pretty gnarly, so I decided to play with some new chemicals and see if I couldn't get them cleaned up. I threw everything in a tub of Evaporust for a day and let things sit. Holy cow does this stuff work!
            Before pics:
            In progress
            Half done
            All done!
            Damn that stuff works!!
            Then it was on to the heat shields. They had seen better days, so I figured I would clean them up with a wire brush and get some POR 15 on them.
            Before:
            After the wire wheel
            I then hit everything with the POR grease remover, then the metal prep stuff. Once it was all clean and ready to go, it was time for the POR 15!
            Aww yes! That's nice. I bet these things will last another 30 years!
            • 95maxrider
              • Oct 2012
              • 393
              #291
              Next up was more rust repair/prevention and playing with chemicals.
              The battery box had a pretty sizable rust hole in it, and I wanted to keep things from getting worse. I also had to get some protection on the metal Josh welded in for the gas pedal. First up, I hit everything with the VHT Rust Converter spray (not shown). It sprays on clear unless it contacts rust, which it supposedly neutralizes, and then turns black.
              Battery tray before
              Gas pedal metal before
              After the VHT spray:
              And some POR epoxy putty to keep water from getting in anywhere
              And finally the 3M rubberized undercoating spray
              Aww yes, more rust protection!
              • 95maxrider
                • Oct 2012
                • 393
                #292
                Next up was a project I had been putting off for too long, which was rigging up some plastic to keep water and dirt from getting into the engine bay. As the before pictures will show, it was a straight shot from the front tires to things like the alternator, belts, radiator, and indirectly to my electric fan thermostat. I had some left over fender liners from my Infiniti, so I hacked them up and got busy with the zip ties!
                Very unprotected
                Much more protection
                Other side before
                And after
                And just like that, I kept all sorts of crap from flying into the engine bay.
                • TeXJ
                  • 1914
                  #293
                  Is this the same car that got hit by the Semi this weekend?
                  1990 325is
                  m52b28
                  3.73lsd
                  • TeXJ
                    • 1914
                    #294
                    I forget sometimes that forums are not setup like FaceBook in regards to notifications... :D
                    1990 325is
                    m52b28
                    3.73lsd
                    • 95maxrider
                      • Oct 2012
                      • 393
                      #295
                      And now for the last repairs and mods this car will ever see.
                      After getting the gas tank sealed up, I went for a drive, only to find out my electric fan wasn't turning on. Hooray, another problem!
                      Being as incompetent as I am with electrical diagnosis, I first threw new parts at it, hoping one would stick. First up was the relay for the aftermarket thermostat. The one in the car had some corrosion on one of the tabs, so I figured it could have gone bad inside, but no dice. Next up was the power wire coming from the thermostat to the fan. The connection looked rather nasty (corroded?) so I put a new one together.
                      Still no dice. Thankfully, I know a lot of people who are a lot smarter than I am, and they're all quite generous when it comes to helping out with my car. Our buddy Stephen who co-drives the ETA E30 with us at rally came over a lent a hand reading the improperly printed instructions for the thermostat and making sure we did things right. We yanked out the old probe from the radiator and hit it with the heat gun, but no fan. At this point we were pretty sure it was the thermostat, so we wired up the new one. This time instead of giving it constant power, we sent the trigger wire to one of the things in the fuse box that only gets power when the ignition is on, so the fan doesn't run for 15 minutes after I turn the car off.
                      All wired up, and the fan works again. Hooray!!
                      The following pictures shows two things: the amount of water that comes into the engine bay without any plastic protection, and a curious clean spot towards the back of the motor. What could that be from? Oh look, the tee for the windshield wiper fluid was pissing all over the place!
                      A simple vacuum tee to the rescue!
                      Boom, done! Now with about double the pressure and fluid output. Another win!
                      With the plastic shields in place, I decided to clean things up and see how effective they are after a race.
                      And then....
                      • 95maxrider
                        • Oct 2012
                        • 393
                        #296
                        Unfortunately, it is :(
                        • TeXJ
                          • 1914
                          #297
                          Sorry to hear :(
                          1990 325is
                          m52b28
                          3.73lsd
                          • 95maxrider
                            • Oct 2012
                            • 393
                            #298
                            Rally-x #7 and RIP
                            At this point, I'm just going to say that the car felt better than ever, and was a blast to drive. I drove pretty well and ended up in second behind the relative newcomer Corey and his turbo Volvo. I let the two Golden brothers co-drive the car, and it never skipped a beat. Josh has first locked in for the season, and with this I should lock second, if I didn't already. There was one mini pond we drove through that thoroughly coated the cars with some real photogenic mud. My center grille fell out at one point, but thankfully didn't get run over. The hood latch on the drivers side sheared off in the morning, and we had to ratchet strap it closed for the drive home. Our not OEM at all bolt solution didn't seem to latch.
                            Check out the new CAI!
                            On the way home, I got hit by an 18 wheeler when traffic in front of me slammed on their brakes at 65 mph. I realized I wasn't going to stop in time without hitting the car in front of me, so I started to pull off onto the left shoulder. As I'm coming to a controlled stop next to the car that used to be in front of me, the semi slams into the back of both of us and sends me flying down parallel to the road in the very wide grass median. My gauges turned off, but the motor was still running. I was bolted in tight to the harness, which I had luckily tightened up a bit about 10 minutes before the accident. Had I not pulled off the shoulder like I did, I would have been sandwiched between the Mercedes SUV in front and Volvo semi behind.
                            The semi driver admitted fault, so I had my car towed home and slept for 9 hours. I assessed the damage today.
                            My plastic shielding worked through all the mud!!
                            I just couldn't resist!
                            • stonea
                              • 2890
                              #299
                              Man sucks about the car, but at least you were ok. Cars (especially race cars) are expendable. Although it looks like you could cut the back end off and make a e28 hatch back....
                              My Garage
                              Feedback
                              • phenryiv1
                                • Jul 2009
                                • 3246
                                #300
                                Wow, that is a LOT worse than it looked in the picture you sent last night. Like I said- at least you had a safety seat and harnesses to protect you from the impacts. This could have been a LOT worse.
                                Really glad that you are able to type that post.
                                Patrick Henry
