You've verified the lines aren't backwards, I assume.
Scum class 318 + Mtech + vortech v2 + unicorns - vortech + Turrrrbo
Yes!! The car started and ran for 20 seconds in it's current configuration before
However the fuel pump no longer primes. I noticed there is 3 ohms resistance between the fuel pump power wire and ground, not sure if that's normal
I'm going to check out the wiring because the fuel pump runs while I crank the motor. However the hose did not pop off until I hooked up the pump directly to the battery, might be a bad connection in the wiring
84 325e Burgundrot S52 M Tech 1.
http://www.r3vlimited.com/board/showthread.php?t=250109Comment
That bitch started!!!
Put in a fuel filter with 1/2" fittings and got 55psi fuel pressure and it started up
Fuel Priming problem went away too.
Real shitty update this time, I've been working on my car on and off with my girl. Too busy teaching her car stuff to take pictures.
The cluster is back in and working, interior is nearly done.
Had to rebuild the clutch master cylinder yesterday. The internal spring snapped and the piston would not return, what a bitch.
Last things that are left is the exhaust and wiring in the e-fan, and it'll be road worthy.
After that it's off to smog, and then it'll be time to slam on the aftermarket mods!! Fuck yeah
I just hope theyll give me the SMOG sticker despite the gauges
Hopefully I'll get some pics up for you guys
wow:)-1986 S50Turbo Sedan (475WHP/417WTQ) Castromotorsport Built (Sold)
-1987 Coupe (17x10.5"/17x14")
Castromotorsport / Buddha_Concept_designs Built *UnderConstruction*
Follow me on Instagram: obes_sebo
For more updates:)
Purchase FeedBack http://www.r3vlimited.com/board/showthread.php?t=278838Comment
Hell yeah! Awesome build.
Keep up the good work.
Such a crazy deal to get that mtech 1 kit for $400 with bumpers!!PNW E30 Crew : 1991 E30 S50, 2000 E39 M5
Follow my S50 build : MY S50 E30
Follow me on instagram : @damendesign
E30 T-Shirts | M3 T-Shirts /PrintsComment
OK I looked but didn't see it posted. What are the wheel and tire specs?For all things 24v, check out Markert Motorworks!Originally posted by mbonanniI hate modded emtree, I hate modded cawrz, I hate jdm, I hate swag, I hate stanceyolokids, I hate bags (on cars), I hate stuff that is slowz, I hate tires.
I am a pursit now.Comment
Im in mountain view! Hope to check out your car/ see you driving around the area. Nice build!
1992 e34 Touring- S50 Swap
1992 325i-S50 Swap (SOLD)
1991 Brilliantrot Convertible 80k Miles (SOLD)
1992 318i Convertible Project-Finished (SOLD)Comment
DREWLIENTE
