6/83 grey market 323i.. mtech I S50 5-lug
  • pandaboo911
    • 2070
    #406
    Originally posted by kronus
    updates! surprisingly!
    painted tank
    Bruh where's the hole for the fuel pump carrier
    • kronus
      • Apr 2008
      • 13032
      #407
      it's taped up
      cars beep boop
      • bradnic
        • Jul 2012
        • 3554
        #408
        sorry for off topic.. I know you can swap in m3 hubs in the rear pretty easily, but what's the story on the front? it's alot more involved than that right? full strut swap? also m3 front wheels have a wider track than normal e30. then there's the wider track on the IX... Maybe going 5 lug m3 on an IX isn't as hard.
        i have a headache now.
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #409
          I think most do m3 hubs in the rear and the. Either swap to m3 struts up front or go to the e36 front suspension
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • iXguido
            • Nov 2009
            • 730
            #410
            What exactly are you trying to do? 5lug ix conversion?
            • bradnic
              • Jul 2012
              • 3554
              #411
              that's exactly my question. and a poor man's bbk of course. anyway don't want to pollute the thread. just thinking here.
              HOWTOs:
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • kronus
                • Apr 2008
                • 13032
                #412
                For the front I am using max399's hub sleeves, e36 bearings, e46 328i rotors and calipers. E30 m3 stuff is too expensive, e36 stuff has geometry issues, and e46 m3 stuff does not fit over 16" wheels.
                cars beep boop
                • bradnic
                  • Jul 2012
                  • 3554
                  #413
                  THAT's what I wanted to know, plus IX specific info thanks Kronus.
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • kronus
                    • Apr 2008
                    • 13032
                    #414
                    M3 wheels have a wider track to fill the wider fenders.
                    There was an option in development to use e28 strut housings, but it required a totally custom lower bracket and I don't think the guy ever got too far designing it. Sleeves are easier and far cheaper to machine.
                    cars beep boop
                    • kronus
                      • Apr 2008
                      • 13032
                      #415
                      Also, most don't do e30 m3 hubs in the rear, they use e36 to stuff but that results in a wider track that requires e36-offset wheels to work right. Z4 hubs have a similar issue.
                      E30 and ti trailing arms are identical afaik, but e30 m3 hubs are narrower and require different caliper carrier brackets. Ti ones are modifiable to work with e30 m3 brake rotors, but it's a pain and kinda sketchy. I lucked into a set of carrier brackets off blunt's m3 so I went with e30 stuff in the rear.
                      cars beep boop
                      • kronus
                        • Apr 2008
                        • 13032
                        #416
                        I am working on getting the wiring sorted. For posterity, here's the pinouts of a early square C101, a late round C101, and a '95 X20:
                        and here's the transformations needed to adapt an early body plug to a S50 harness
                        I would adapt the body to a male X20, but the amount of pins that would go unused bothers me, so sticking to a C101. new pins are on their way from BMW, and a DIY on packing an S50 harness into an M42 harness housing will be forthcoming.
                        cars beep boop
                        • kronus
                          • Apr 2008
                          • 13032
                          #417
                          Yesterday I pushed the 5-lug M3 hubs into the trailing arms. It was straightforward, and ultimately not significantly more expensive than 318ti arms would be.
                          bearing going in
                          yup it's in
                          hubba hubba
                          done!
                          I can't put on the brakes yet because the e-brake cables are still on the car and I'm not sure if I want to remove them.
                          next up, getting the old ass end out of there!
                          cars beep boop
                          • kronus
                            • Apr 2008
                            • 13032
                            #418
                            soo, bad news (sorry 2mAn)
                            I took the S50 apart further and had a good look at the cylinder bores. It has deep scoring down 3 of the bores, and most of the pistons have valve contact. The valve contact is not a huge deal breaker (they're mostly intact, ring lands don't look crushed), but the bore scoring is deep enough to require an overbore.
                            I'm thinking to overbore to S52 specs and find an S52 crank and pistons. Sadly this expands the timeframe of the car's completion by a lot.
                            Anyone have an S52 rotating assembly hanging around?
                            cars beep boop
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #419
                              Why not sleeve those three cylinders?
                              • 2mAn
                                SeƱior Mod
                                • 21088
                                #420
                                ugh.... this sucks.
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
                                Make R3V Great Again -2020
