RedMeat: LS6 Powered, M3 Flared, LTW Project - SOLD
  • XvillainousX
    • 176
    #31
    subscribed
    • YAN-3
      • Jan 2004
      • 6018
      #32
      Ok I'm in for this too
      • Jb325is
        • 2137
        #33
        Wow. Great work so far. I wish I had the spare time to embark on a project like this.
        - '88 m54 coupe
        <3
        • 89is
          • Dec 2010
          • 224
          #34
          This is gonna be good, subd
          Originally posted by Wh33lhop
          If you actually stay within your budget, you are not a true car enthusiast. True story.
          • unloadedak
            • 1197
            #35
            Well last week I started the final stages of stripping the undercoating off.. the passenger front wheel well is the last thing I stripped!
            So glad that is all over with. I would estimate I have 70-80 hours into the stripping process.
            Then this week I learned how to MIG weld by starting to mess around with my buddies welder that I've had in my garage since I started stripping.
            After messing around on a spare tail panel I decided to jump right into stitching the chassis.
            I need to go back and redo some welds from the beginning and some that just don't meet my standards of work quality.
            Being a 115V welder you have to make sure the metal is CLEAN since the rubber undercoating inside the seam (that you will never get 100% out) will pop and contaminate your welds.
            You can't have any other issues with primer still being there or any other contaminate.
            I'm about 80% done stitching the chassis. I called it a night and took the drop cloths down to sweep and blow out the garage.
            What an easy cleanup (compared to IronFreak's garage ;))
            Updated to do:
            finish stitching/paint underside
            take off the rotisserie
            tail panel replacement
            rust repair
            fiberglass flares/hood/bumpers/skirts/sunroof mounting
            hydraulic e-brake fab
            removable core support
            CAGE
            back onto rotisserie
            install fuel tank/lines
            refresh/install suspension
            fill in door molding recesses
            cut/mount lexan rear quarters/rear windshield
            body work prep
            PAINT
            all this by 2014ish is the plan... and school starts next monday :(
            2003.5 Imolarot M3: daily
            1995 Alpinweiß M3: hpde
            • kingston
              • Jun 2010
              • 2669
              #36
              Great work, Adam!
              CAGE ALL THE THINGS!!!!
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • FunfGan
                • Jan 2011
                • 4958
                #37
                This will be so awesome.
                I've also been looking for the link to the Czech parts for the longest time, so a bonus surprise :)
                Go here be happy!
                Ratchet Garage e30 V8 build.
                • IronFreak
                  • Dec 2012
                  • 3702
                  #38
                  Looks good man, I'll have your sheet metal this weekend.
                  Instagram @rebellionforge
                  • silence
                    • Jun 2007
                    • 1824
                    #39
                    looking good, Thats a lot of work!
                    • matthugie
                      • Mar 2004
                      • 1810
                      #40
                      Wow, this looks amazing. Definitely in to watch the progress.
                      88 325is - S52 powered
                      Originally posted by King Arthur
                      We'll not risk another frontal assault, that rabbit's dynamite!
                      • series88
                        • Nov 2011
                        • 1231
                        #41
                        Keep hooning in this thing. It looks like a boat load of fun
                        • unloadedak
                          • 1197
                          #42
                          I started this labor day weekend doing a ton of work on the car.
                          First I took it off of the rotisserie and 'fixed' the rotisserie to make it a set of extremely tall jack stands so all of the body work is at working height.
                          I then grabbed all of the fiberglass parts and started to mock them up with masking tape.
                          Then I took the angle grinder and took off one of the rear flares to see how stable the fiberglass would be with no support on the arch. Check out all that bondo lol
                          It's fairly stable but I will probably add in my own flare just to push it out more so I can fit more tire ;)
                          Front fenders are totally mounted and fit pretty damn good.
                          Next is to order some cleco clamps, rivets and other fab stuff to get all this stuff mounted.
                          • kingston
                            • Jun 2010
                            • 2669
                            #43
                            Wow, Adam, what an update!!!!!!!!! Schön!!!!
                            #teamross
                            • Bimmer_man
                              • Jan 2013
                              • 1478
                              #44
                              Im subbed this looks nice man keep it up.
                              Float like a cadillac sting like a Bimmer!:)
                              • unloadedak
                                • 1197
                                #45
                                Fabrication and mounting stuff happened this last week. I got a ton of fiberglass mounted and it's going really good.
                                Couple phases of bumper mounts shown. Final version being euro bumper mounts with extended portions chopped off with some square tubing and an M12x1.75 nut welded to the end. I have about 10 hours of fab time into these mounts, such a PITA when you're the only one holding the bumper up and measuring.
                                I needed to push the fenders out to be flush with the wider bumper, I was in the metric section of ACE hardware for at least 40 minutes trying different stuff out and figuring it out in my head, I finally narrowed it down to an 'adjustable' mount, I'm able to push them out if I need to make room for more tire. Bumper is taped up on the sides right now because I'm going to make a splitter to hold the sides up, waiting on Alumilite pricing.
                                These are just rough welds ;) need to be cleaned up when it's on the rotisserie.
                                I then went out there today and started by taping up the rear bumper and beginning to line up the drivers quarter panel for drilling holes for my rivets, I'm using cleco clamps to hold it on right now (temporary rivets) and they are worth their weight in gold.
                                Then I started the then daunting task of cleanly mounting the skirts. I was going to use some of the 3" angle iron from the rotisserie to mount it but it was too heavy, I looked over at a shelf in the garage that is rarely used and thought it was perfect to chop up and use for mounts.
                                I wasn't sure if it would be rigid so I cut a 3.5" strip and it didn't flex at all! I tacked that on and drilled some holes for clecos and it held perfectly and is so solid it moves the car back and forth. I then began to fab front and rear mounts for the skirt as well. Got all everything mounted except the rear bumper and passenger flare/skirt.
                                After that I called it a weekend. So glad that I've almost got it all mounted..
