RedMeat: LS6 Powered, M3 Flared, LTW Project - SOLD
  • unloadedak
    • 1197
    This post is primarily copied from a previous thread to make it less confusing..
    This thread will be my build thread.
    My name is Adam. I am a Mechanical Engineering student.
    I hope you lime pictures.
    This will be a slightly slow build. Plan is to be "done" by next summer.
    I daily an S52/5 Lug/IE3/GAS E30, so I don't have a rush to get this done. I can hoon every day.
    I started back in mid 2009 on this 87 325iS and it went through multiple phases.
    It ended up being an S52/ZF/5 Lug/Euro drift/autox/daily.
    The S52 is currently in pieces and will be rebuilt. (it's now being sold)
    The plan for this phase is: [updated 1/15/15]
    -Refreshed LS1 w/ TKO600RR & 3 clutch 3.73 LSD & CATuned Axles
    -E36M/Ti 5 Lug w/ C6 Z06 Brakes
    -Z3 Rack
    -MCS/FEAL/Fortune Auto Dampeners
    -Seam Welded, Gutted, & Caged
    -Tubed Front & Rear Ends
    -Recaro Profi-SPG with Willans Harnesses
    -Fiberglass E30M Flares, Hood, Trunk, Bumpers, Doors, & Skirts
    -Carbon Fiber Roof
    -BCL Wing
    -Custom Body Harness
    -APEX ARC-8 18x10" et25 w/ 285/30 R888s
    -Full Imolarot Exterior, Alpinweiß Interior Respray
    -Lexan Windows
    -Wilwood Pedals
    -RaceTechnology DASH2 PRO
    -<2,300lbs w/o driver
    From first day to last day it drove..
    /history
    I got the sound deadening out and started to pull the harness.
    Then took a knotted wheel to all the seam sealer to prep the seams to be stitch welded.
    I ordered some flares from Czech Republic and traded for some Recaro Profi SPG with VAC mounts from a member on here..
    Which brings me to today..
    I received the flares and figured my build thread was CONFUSING. So time for an organized one.
    I started to take the sunroof cassette out and that ended in a very successful manner.
    I then cleaned the garage and started preparing for the rotisserie.
    Next morning USPS calls me "HEY! We have some huge packages for you, will you be home?"
    PESCH flares were on their way.
    I got them taped up as good as possible, jackstand kinda blocked the skirt though.
    I'm taking summer classes so this might have slow progress. I need to hook up 220V in the garage and then it'll really get rollin.
    2003.5 Imolarot M3: daily
    1995 Alpinweiß M3: hpde
  • kingston
    • Jun 2010
    • 2669
    Subscribed!
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
    • PaladinReed
      • 1524
      I too need to hook up 220 for my welder. Do you have an external or garage only breaker box? Is it just a matter of installing wire and breakers into the box and hooking up an outlet?
      Wiring is not my thing needless to say and I don't really want to pay someone to do it
      Late model granitesilber 325i convertible FS:
      http://www.r3vlimited.com/board/showthread.php?t=293701
      • unloadedak
        • 1197
        I have no idea what the plan is... my dad knows electricians who are going to do it for us. What I've gathered is they are gonna run wire down to the main box in the basement since we still have open amps on it.
        After about 6 hours in the garage I'm calling it a night until the morning.
        Got the skirts taped on pretty good, can't wait to get this thing going!
        Rear subframe removed.
        TONS of trash out of garage.
        Organized.
        I'll attack the back half of the garage tmrw. It's a disaster.
        • IronFreak
          • Dec 2012
          • 3702
          You did work son!!! Garage looks nice
          Instagram @rebellionforge
          • TheTacoMan
            • Nov 2011
            • 2308
            My glob, so sweet.
            • unloadedak
              • 1197
              Originally posted by TheTacoMan
              My glob, so sweet.
              hahah thanks man!
              I've been going crazy working on the car, going from 8pm until 5am for three straight nights.
              I've made a ton of progress:
              Harness out and completely weeded through cutting out unnecessary wires.
              Fuel tank out
              Garage super cleaned out
              I am hoping for rotisserie next weekend. We will see though.
              I'm still not sure what to do with my windows. I don't want to use power windows, harness simplicity.
              I want to cut out all unnecessary metal in the doors so manual swap wouldn't work. I want it to be fairly weatherproof.
              So, I think my best/lightest option would be gutting the doors and making a fixed type of lexan that is easily dropped into the door or removed.
              Almost done stripping the interior out. Using a knotted wheel and lacquer thinner to remove adhesive and ran out of thinner.
              Preliminary deciding what to cut. Green is keep. I ended up removing some green items.
              Trash wires.
              Final harness for the entire car.
              I couldn't have done it without this bad boy. 100000x easier than reading a pdf.
              oh, and.. dem flares...
              • cmcgrogan
                • May 2013
                • 240
                What did the skirt and flares cost you? Where did you get the too?
                Originally Posted by scaraveos
                Are saying about welding the head to the block? and if yes how is it seperated if required?
                (possibly a stupid post)
                • unloadedak
                  • 1197
                  I got the flares, skirts and hood for $800 shipped. I'm thinking of placing another order soon for some more parts; sunroof panel, trunk and possibly their FG doors.
                  • cmcgrogan
                    • May 2013
                    • 240
                    do you plan on glassing them to the metal, riveting them, or some other way? 800 shipped from the other side of the pond sounds like an awful good price if you think about how large those things are. Granted they do not weigh a whole hell of a lot.
                    • george graves
                      • 19992
                      Subscribed.
                      Originally posted by Matt-B
                      • unloadedak
                        • 1197
                        I'm not sure what I will do... I want to mold them in but at the same time it's a racecar and rivets are awesome. I'm planning on tapping some walls/doing some tandem drift events so I will probably just rivet them. I want to make a mold before I put them on as well.
                        The flat shipping rate is 115 euros. So take whatever you want on the site and add 115 euros. Paypal exchange rate was different than Google so add some additional money onto it.
                        The quality is racecar, but it's not BAD. Fitment is pretty damn good, hence ordering more stuff soon.
                        • cmcgrogan
                          • May 2013
                          • 240
                          Exactly what I was going to say. Riveting sounds like the best bet if you plan on strictly drifting. Once you make a mold ill buy a set of yours 8-)
                          • unloadedak
                            • 1197
                            That is what I was thinking as well. It's gonna be subject to abuse and the last thing I want to worry about is messing up my week long effort of meticulously blending the panels into the car lol.
                            My plan was to make several sets for sale as well. You wouldn't have to wait 6 weeks for them either :)
                            • IronFreak
                              • Dec 2012
                              • 3702
                              Ill tap your ass in a tandem run......
