Melted a piston, now LSX Turbo
Bang Gears & Burn Rubber.
Instagram: @Dirk_LSXT
Buy my m20 racecar parts, help fund my lsx turbo swap.Comment
What are you going to use for lines and do you think the LS pump has what it takes to run that rack?sigpic
Instagram @rebellionforgeComment
6an Teflon for the pressure side and normal 6an for the low pressure side.
Plenty of guys use the camaro pump in their e36s and this is an e36 rack so I don't see any problems with it. We will seeBang Gears & Burn Rubber.
Godamn I love this build..!! Makes me a want turbo v8....to be honest I secretly yearn of building one.
Will you have to massage the firewall/foot well area to fit the trans?Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
Thanks Otis, I cut down the reverse lockout and welded a cap on the back so it has a smaller profile because it hit the trans tunnel. I need to "clearance" the trans tunnel in one spot and it's all set.Bang Gears & Burn Rubber.
