Just a little insight, make sure you use cast rod on those manifolds.  I suggest talking to your welding supply shop when buying filler.  Make sure you get someone that welds.  Hopefuylly those won't crack.  Also you may need to get a few other bottles of gas for stainless and back purging .  looking great so far.
					Melted a piston, now LSX Turbo
 Those manifolds aren't cast......and I'm almost sure that's mig welded....Just a little insight, make sure you use cast rod on those manifolds. I suggest talking to your welding supply shop when buying filler. Make sure you get someone that welds. Hopefuylly those won't crack. Also you may need to get a few other bottles of gas for stainless and back purging . looking great so far.sigpic
 Instagram @rebellionforgeComment
 Bang Gears & Burn Rubber.
 Instagram: @Dirk_LSXT
 Buy my m20 racecar parts, help fund my lsx turbo swap.Comment
 Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
 ____________________________
 E-mail Panayiotisx2@gmail.com
 Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
 Where are you ordering your driveshaft from? I need to order mine soon.1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
 COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
 pretty sure he's having one custom made since none of the swap kit people (to my knowledge anyway) use flanges for 1350 u-joints. google "driveshaft shop" and pick whatever's local (i'm not talking about the company called driveshaft shop btw). if nothing comes up on google for your area, call up some local trucking companies and ask them where they get their driveshafts done. it's about $200 + the cost of the yoke/flange for most places to make you a shaft from scratch
 also, to backtrack a little bit...
 i remember watching a video about rebuilding these diffs, that surface is apparently heat treated. do you think it'll be fine without having it re-treated?Comment
 I'll let you know soon enough, I'm not worried about it but time will tell.pretty sure he's having one custom made since none of the swap kit people (to my knowledge anyway) use flanges for 1350 u-joints. google "driveshaft shop" and pick whatever's local (i'm not talking about the company called driveshaft shop btw). if nothing comes up on google for your area, call up some local trucking companies and ask them where they get their driveshafts done. it's about $200 + the cost of the yoke/flange for most places to make you a shaft from scratch
 BimmerDiffs says to just mill it and slap it together and the swap program they offer all they do is mill it 4mm and send it to you.Bang Gears & Burn Rubber.
 That surface should be ok, wouldn't hurt to do it. it's the ramp carriage that has the Rockwell rating that needs to be heat treated if messed with.sigpic
