Jntar's 318is budget Turbo build...no longer on a budget :(
  • jntar
    • 459
    Got some more work done today on the car.
    The new intercooler is massive. It's going to take a lot of body work to get it to fit. I'm going to first get it running on the small cooler to see where my intake temps sit before I go balls out and start cutting.
    M42 turbo build.
    http://www.r3vlimited.com/board/showthread.php?t=301330
    • jntar
      • 459
      Getting there. Hope to be finished tomorrow. Still need to install the oil pressure sending unit, install and calibrate the wideband o2, and gauges.
      M42 turbo build.
      • jntar
        • 459
        Got it started and driving, but have a couple of things I need to work on.
        1)Had pressure in the crank case so I vented the valve cover to atmosphere until some couplers come in to route it over to the intake.
        2)While working on my oil line it started leaking. Pulled it apart and redid the connections only to find it had stripped one of the major fittings. Decided I didn't want to deal with this line and trying to make a diy oil restrictor so I ordered a new line and fittings.
        M42 turbo build.
        • bradnic
          • Jul 2012
          • 3554
          Update??????
          HOWTOs:
          DB vert plastic bumpers
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • jntar
            • 459
            New oil pressure line. Added a 1.5mm restrictor instead of the 2mm one that was on there. Was blowing smoke on decel and at idle. Oil leaking from turbo.
            Rerouted valve cover hose to turbo intake side. Crank pressure issue is solved.
            Moving the oil return to the front of the upper oil pan. Turbo is pissing out everywhere. Bought a new one. Waiting for it to arrive.
            M42 turbo build.
            • jntar
              • 459
              Got the front back together. Still need to re-weld the downpipe bung (it has pinholes) because it's giving bad AFR readings. Also need to move the oil return to the front of the upper oil pan to solve any backup issues. Finally, the new turbo arrives next week. We'll see if that solves the leaks.
              M42 turbo build.
              • bradnic
                • Jul 2012
                • 3554
                front end looks great!
                you have PM.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • bradnic
                  • Jul 2012
                  • 3554
                  Originally posted by jntar
                  that bung looks really close to the turbo. the sensor may not last due to the heat..
                  clamps look great
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • Peattie
                    • Apr 2013
                    • 260
                    What turbo are you getting?
                    • jntar
                      • 459
                      Same turbo so I don't have to remake the downpipe/manifold.
                      M42 turbo build.
                      • jntar
                        • 459
                        New turbo has been on for about 500 miles. All oil burning and leaking issues are gone. I am noticing some fuel cut issues at higher rpm in third and forth. No other gear. Going to order a Walbro pump and hope that solves the problem. She is almost complete!
                        M42 turbo build.
                        • jntar
                          • 459
                          Looks like Jake's tune isn't going to work for me. I am still getting fuel cut with the new TRE 255lph pump and also some major detonation between 2k-5k rpm. I went with colder plugs and still have this issue.
                          So I could only think of one solution to my problem. Megasquirt standalone.
                          M42 turbo build.
                          • Dj Buttchug
                            • Jun 2010
                            • 7686
                            how much boost op? wideband? If you have been this lean for this long you might have done some damage. :(
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • bradnic
                              • Jul 2012
                              • 3554
                              Good points. You did get a wide band right? Did you pull the head or anything? Timing chain isn't advanced 1 tooth or something? I had no detonation with this setup
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • jntar
                                • 459
                                9psi with a short 10psi spike before it equalizes. Motor is still fine. The Detonation just started when the temp finally got cold here. It's got to be a timing issue with the tune. I wanted the megasquirt from the get-go if you remember our PMs and this was just the final push to make me spend the cash.
                                AFRs are good, could be a little better at higher rpm/throttle, but nothing that would cause the Detonation. It's always at higher load/low rpm. The fuel cut is at high rpm and load.
                                M42 turbo build.
