2002 325xi automatic. Work and wife friendly. Got a compression test and it is A-OK!!
One out of three working ain't bad.
Head ready to rock and roll!
Done with the block prep. Used a stone, then went to 600 grit sandpaper with WD-40 for the lube. The finish was glass so I called it quits after the 600.
Fresh ARPs
Hondabond on the timing cover.
Cut Rings!
Perfect fit.
New one-way valve.
ARP lube but not too much. Used a rubber mallet to knock in the steel dowels. Also took brake cleaner, Q-tips and pressurized air to clean out the block threads. Used these three steps about three times. Some holes were dirtier than others. :nice:
Initial torque to 35 ft/lbs after triple checking the cut rings were sitting properly.
Tapped the M50 manifold with a 1/8 NPT tap for the multi-port meth install.
The .4mm jets for the intake runners. Also have a single .7mm jet for a pre-throttle body nozzle.
Distribution Block.
Snapped a jet from over tightening...
6 gallon Meth tank.
Wangmanstyle Diff Install!
Torqued the head to 65 ft/lbs after I re-torqued the bolts to 35 ft/lbs this morning. About 5 "jumped" to an easier spot (about 30 ft/lbs) at this stage then tightened to 65 ft/lbs if that makes any sense.
Started to wire up my oil temp gauge. Also replaced my oil pressure gauge with a new one.
Used fish tape.
Hardwired my V1 detector.
Rigged up a broken vent.
Retorqued the head studs to 65 this morning. A couple were loose. Retorqued them again around Noon. I'll check tomorrow to see if any move. If they don't I'll go up to 85 ft/lbs.
Cut into the VSS coming out of the speedometer for the rear wheel speed input to the Traction control chip. Still have to cut the front left ABS wires and run them into the cabin.
Pulled the wires through the firewall for the oil pressure and oil temp. Still need to install the sending units.
Oil temp setup. Had to drill out the 1/4 to 1/8NPT fitting so the VDO sensor could get all up in. This will be picking up the temp from the cold side of the oil cooler.
I don't think I could have fit a bigger cooler in there. The grinder was used a fair amount and the mounts are temporary...haha
