E30 S52 Build + Turbo Install
Instagram: @DrLeadFoot
Build Thread for the Turbo S52:
http://www.wibimmers.com/board/index...turbo-install/
Running log of the daily E46 M3:
http://www.wibimmers.com/board/index...46-m3-journal/
Flickr
https://www.flickr.com/photos/70254549@N06/
What are you running for tuning? Im trying to figure out a megasquirt set up v3 for my s50 turbo i have been working on88' E30 325 24v Turbo Coupe
91' E30 325i Sedan
09' E82 135i Coupe (Sold)
01' E46 325ci Coupe (Sold)
97' E36 328is Coupe (Sold)
91' E30 325i m52 Coupe (Sold)
90' E30 325is Coupe (Sold)
90' E30 325ic Coupe (Sold)
88' E30 325is m20 Turbo Coupe (Sold)
88' E30 325 Coupe (Sold)
87' E30 325e Coupe (Sold)
86' E30 325es Coupe (Sold)Comment
Sent from my SM-G900V using Tapatalksigpic
Flickr
Where are the directions for this thing??!
If you look at the first pic you can see where the connector was digging into the MS3x.
Flickr
Intake Air Temp bung welded by Dan the Exhaust Man.
This transcamarobird was getting a cage custom made by Dan.
Flickr
Cleaned up the carbon build up on the pistons as well as sanding down some detonation marks.
Before:
After:
I also mic'd the ARP2000 head studs:
If you can't read my want-to-be (real) doctor handwriting it goes a little something like this:
All numbers start with 114.xx
---Front of motor---
.33 .32
.48 .37
.40 .26
.44 .35
.42 .43
.32 .34
.41 .30
---Rear of Motor---
I have a couple of theories of why the head gasket was leaking.
1. The bolts stretched due to the tune running super rich and stretching the bolts over time.
2. There was some red loc-tite on the threads of some of the block threads. I had Kummrow torque down the head so I'm not too sure about how fast they torqued down the bolts. If there was any significant time lapse between installing the head bolts and actually torquing down them down to spec with the use of loc-tite the loc-tite would have hardened up with the bolts just sitting there having gravity pulling them down. Then torquing them down wouldn't be a true torque due to the loc-tite in between the threads.
3. Does that red ARP torque lube dry and look like red loc-tite? Then back to theory #1.
4. The bolts were a pain to take out of the block. I needed to use a small pipe wrench to crack them loose. (See theory #2) It took about 25lbs of force to break them loose. To my theory #4, were the bolts tightened down too much making them slightly cock-eyed and when torqued down the force stretched them from the beginning?sigpic
Flickr
2: AFAIK there shouldn't be loctite on ARPs, just their installation lube: http://arp-bolts.com/p/arpultratorque.php
Did you re-torque the studs after a few heat cycles? Some people recommend this, others say it's not necessary, but it can't hurt.
Disclaimer: I've never installed 24v ARPs, only M20 stuff, so there may be differences.Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
Did a little bit of work on the ECU.
BMW coils
Cutting the bottom row of pins on the ECU
Flickr
My buddy is helping me out and trying to straighten out the Good & Tight manifold.
Flickr
Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
This far. The machine over heated twice on him. It was .050 to .060 off.
Flickr
And they're off!
First one done! I think this fuel relay one was supposed to be on a relay. I'll figure it out soon enough.
Got a good chunk started. Also have a lot of questions.
Flickr
are you planning to switch the BIP373 coil drivers from the MS3 out for the ones from the old bosch DME?Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
Flickr
After I posted, I realized that the pre-made MS3 kits don't already have coil drivers, just the circuits. derp. It makes sense now.Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
