Blunttech / Classic Daily S85 V10 E30 M3 Swap
  • FreedomM3
    • Aug 2015
    • 191
    #316
    I hate it when I come to the end of a such awesome content! Can't wait to see this finished!
    Very cool project you have going on!
    Our RestoMod Diary!
    El Mustache De La Resistance!
    • Wschnitz
      • 8089
      #317
      Spoiler: It wasnt finished by September. Spring Vintage goal now? Hahaha
      willschnitz
      • blunttech
        • 12850
        #318
        Yes, Jake and I both had a bunch of stuff that took precedence but hope to be back on this soon.
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • glenn-b
          • Dec 2013
          • 22
          #319
          any updates ?
          • PositivePers
            • Sep 2015
            • 1
            #320
            Loving the build thread! I've been wanting to do this for a few years now, and now seeing more of what's involved is great for planning my dream build!
            One question though: Have you thought about the brake booster? I know with s/m6x builds Garagistic offers a boosterless pedal setup and compensate with a different master/slave cylinder combo to ease the braking force required. But with all that power, it would be nice to have power brakes too, and a bias valve is easy enough to install to tune your system, especially with those lovely calipers tucked in there. It appears (from other v10 swaps I've seen) that the passenger side firewall would have space for the booster, but with my limited knowledge on how the booster works, I have a feeling that it isn't possible to move it laterally. I know you could extend it to the front of the engine bay, but that's not an option really if you plan on using dual intakes. I'm just wondering what your plans are and if you've come up with a viable solution for this yet.
            Keep up the good work though, I'm excited to see it all come together!
            • bobaflesh
              • Mar 2016
              • 69
              #321
              Awesome build, subscribed!
              • jakeb
                • 1909
                #322
                Build was delayed for a bunch of different reasons but things are starting to move along again. The goal is to have it for vintage in NC the endish of May.
                So...back to some updates. This will be a bit of a hodgepodge until I get on a bit more of a schedule to keep up on updates.
                We had taken a cut out of the drivers side frame rail to fit the e60 radiator.
                So then we needed to box it back up.
                And we wanted AC so to fit the compressor and lines a notch was required on the passenger side.
                Will get some custom lines but the e60 ones are a start...
                Fitting the air boxes and making mounts
                Close to the ABS pump....
                Similar setup on the passenger side.
                The trans sits so high in the tunnel that there was NO room for the shifter carrier. So it got chopped and mounted a little different.
                Start with some raw bits...
                Weld raw bits together...I am getting better at TIGing Aluminum but still have a ways to go. It's strong just not always pretty.
                VERY short shifter linkage
                Some captive nuts welded into the tunnel.
                And bolted in
                A video of it working....
                Adapting the E30 to S85 Power steering lines...
                Tig some AN6 fittings on each.
                Then there will be a short line made to connect the two.
                Fit the stock e60 oil filter.
                Start with some cardboard
                Turn that cardboard into aluminum
                Weld and add a gusset (again not super pretty but not terrible...)
                Mounted
                Extra Steering linkage mount needed due to the extra Ujoint. Had to figure a way to be able to remove the mount so came up with this...
                With the engine in the car.
                Hard to tell but there is more room than this pic shows.
                Sway bar wouldn't fit in the stock location so it was moved in front of the subframe.
                Core support is removable so need to make it so it stays in...more captive nuts behind these allen bolts.
                www.classicdaily.net
                1970 m42 swapped 2002
                1985 LS1/T56 Swapped e28 (557e)
                www.blunttech.com - For all your parts needs
                Follow me on Instagram for constant build updates @classicdaily
                https://www.facebook.com/ClassicDailyLLC
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  #323
                  Finalllyyy
                  1991 318i 4dr slick top
                  Mtech 2 turbo restoration
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    #324
                    Always good to see updates on this car :)
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • Kershaw
                      • 11822
                      #325
                      Yay progress! Maybe I'll get to see this in person this year.
                      AWD > RWD
                      • dishwab
                        • Mar 2012
                        • 681
                        #326
                        You guys are cool
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          #327
                          So awesome
                          • goarmy
                            • Nov 2011
                            • 622
                            #328
                            Man I sure like to be next in line on a E28!! I even have an engine sitting around. I didn't think it could be done, such a modern engine...
                            • jakeb
                              • 1909
                              #329
                              email if interested....jake@classicdaily.net
                              • Kershaw
                                • 11822
                                #330
                                If that engine was any further back, you would have been able to bolt the shifter right to the transmission. Lol.
                                AWD > RWD
