88' Zinno M3 (Progress Thread)
  • jhaurimn
    • Nov 2012
    • 2224
    #211
    Originally posted by motors4me
    Did you figure out what holds the wheel chock down?
    I have not, but I haven't looked into it. Its supposed to be a wingnut of some size.
    Things are slowing down a bit on my m3 at the moment. But I've been getting my m3 fix by helping out a friend on his.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • jhaurimn
      • Nov 2012
      • 2224
      #212
      Okay, back to my car.
      I pulled the electric fan out to paint it, as it had a good amount of overspray on it.
      Not quite dry yet when I took this, just used trim paint.
      And finally got the steering rack replaced. Pulled what looks to be from a z3 rack. Cleaned up the m3 rack before putting it in. Also replaced the reservoir and tie rod boots.
      Also did engine mounts at the same time. Was a lot easier to access the driver side mount with the rack out.
      Glad I got the rack swapped before winter. Huge thanks to my friend Erik for helping me out, wouldn't have been possible without him.
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • Bimmer_man
        • Jan 2013
        • 1477
        #213
        your car is just beautiful no comparison.
        Float like a cadillac sting like a Bimmer!:)
        • jhaurimn
          • Nov 2012
          • 2224
          #214
          Not much has been going on, about to put the car away.
          I ended up buying another set of smilies, as the other ones werent quite up to par with the rest of the car. The new bosch set I got is very clean.
          I took the time to replace more cheap hardware that was used for the headlights.
          And to replace the non heatshrink butt connectors I used before. Next time I have the bumper off I will re-do the splices for the city lights.
          Using my 325 with us elips to help aim the lights. For some odd reason, the us elips have better cutoff.
          I replaced my eh looking door cards with some minty ones, with the manual window crank hole, as it should be for a 88.
          Also a friend of mine said my trunk was kinda shaking over bigger bumps in the road, so I adjusted this little stopper on the back. Seems to be better now.
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • jhaurimn
            • Nov 2012
            • 2224
            #215
            Well, I filled the m3 up with non-oxy gas a few weeks ago (to help prevent rust in the gas tank) and put the m3 away.
            I decided to remove the rear spoiler and keep it inside my house to avoid cracking in the paint, which is very common.
            Also, not sure if I mentioned this, but I bought a new oem e30 cover. Fits great!
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • markseven
              • Sep 2006
              • 5327
              #216
              Lookin good!
              What is that under the tires?
              I Timothy 2:1-2
              • jhaurimn
                • Nov 2012
                • 2224
                #217
                Originally posted by markseven
                Lookin good!
                Thanks!
                Just some insulation to help against flat spots. Ill probably roll the car around a bit on them throughout the winter too.
                Current:
                1989 325i
                1988 M3
                1987 325ic
                Past:
                2001 330ci
                2001 M3
                • 2mAn
                  Señior Mod
                  • 20962
                  #218
                  Its 70* in SoCal 8)
                  Whats your winter beater?
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    #219
                    Originally posted by 2mAn
                    Its 70* in SoCal 8)
                    Yeah yeah yeaaaaaahhhhhhhh.
                    I drive my 89 325i in the winter. :)
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • 2mAn
                      Señior Mod
                      • 20962
                      #220
                      Just busting your balls, nice that you have another great car to drive in the snow. Driving a E30 in the snow isnt so bad. I love this pic of my old Zinno ES. Surrounded my SUVs :rofl:
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • Bimmer_man
                        • Jan 2013
                        • 1477
                        #221
                        Any updates on this beauty?
                        • cabin
                          • Dec 2006
                          • 552
                          #222
                          From the picture you posted showing the headlight cutoffs, you have your ellipsoids setup for RHD. You will be blinding the hell out of oncoming traffic like that. The uptick should go up to the right, to illuminate road signs. You should be able to loosen and rotate each projector to switch them to LHD.
                          -Justin
                          Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                          • markseven
                            • Sep 2006
                            • 5327
                            #223
                            Originally posted by jhaurimn
                            Is there a build thread somewhere for this one?
                            I Timothy 2:1-2
                            • Court M3
                              • Jan 2004
                              • 6713
                              #224
                              I like what you are doing to the car, might have to spend some time in the US doing the same.
                              Keep it up, love the progress you are making
                              Continuous For Sale Thread
                              323i s50
                              • jhaurimn
                                • Nov 2012
                                • 2224
                                #225
                                It is stored away for the winter. I have plans for the spring, though. :)
                                I realized that once I turned the lights on. I switched them to LHD after I took the pictures.
                                Nope. We kinda just knocked it out and didnt spend much time taking pictures or anything. Swap was completed though in relatively short time. Thing is a beast, and the csl box sounds AMAZING.
                                Thank you. Definitely will continue the progress once spring starts rolling around...
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
