88' Zinno M3 (Progress Thread)
  • pilotskillse30
    • Dec 2006
    • 1957
    #241
    Awesome work
    • jhaurimn
      • Nov 2012
      • 2224
      #242
      Priorities have changed a bit...
      I got my injectors back from mepeh. They apparently were in great working condition already.
      Before
      After
      I also bought a new walbro fuel pump to replace my in tank pump (I believe its dead), and a new fuel pressure regulator.
      I went to Tim's Custom exhaust, 20ish minutes north of downtown Minneapolis to get my muffler properly installed. The exhaust clamps I used leaked pretty bad, and the muffler kinda hung down a little low.
      Unfortunately, my transmission has been sounding a little loud lately. Ive heard some people say its normal getrag rattle, and some that say it needs a rebuild. I plan to first swap mt90 fluid into it to see if that has any effect. Then I will pull the trans and replace all clutch/shifter related parts. If the noise still seems excessive, I will look into replacing the bearings in the transmission.
      New pressure plate, clutch
      Release bearing, pilot bearing, pressure plate bolts, bell housing spring, pivot pin.
      I also noted that the pilot bearing doesnt have any casings around the actual bearing...I thought that was odd. I bought this one through blunttech but ordered a new oem one in the hopes that it has casings on the bearing.
      The one I got
      The picture from ecs for the genuine bmw part
      And the procedures to install it, nice to have. Figured it might help someone
      So because of the transmission stuff, all my suspension stuff is getting delayed a bit. But when the transmission is out, I plan to replace all the shifter components. I also bought a z3 1.9 shift lever, we will see if I like it. ;)
      And just a quick two pictures to show how shes looking currently
      Current:
      1989 325i
      1988 M3
      1987 325ic
      Past:
      2001 330ci
      2001 M3
      • 2002jm
        • Sep 2005
        • 2076
        #243
        such a nice car
        Enjoying this thread, wishing I had kept mine:).
        jm
        • bradnic
          • Jul 2012
          • 3554
          #244
          Great pics. You've got your priorities straight I think :-)
          If you're doing bearings I assume synchros too..
          Nothing like a rebuilt shift linkage.
          HOWTOs:
          DB vert plastic bumpers
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • CurrusDei
            • Mar 2014
            • 673
            #245
            Looking good man. Can't wait to get mine looking more like a car and less like a pile of parts
            _______________________________________________
            5 Year M3 Build, In Progress
            RMT200 Retrofit
            • jhaurimn
              • Nov 2012
              • 2224
              #246
              jm
              Thank you!
              There are no issues with the synchros right now, so I would probably leave those be.
              Thanks! At least youll have everything covered. Im discovering something new every week ;)
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • Bimmer_man
                • Jan 2013
                • 1477
                #247
                Dude I love your build. Imo one of the cleanest e30 m3s on r3v. Keep it up man. Beautiful work.
                Float like a cadillac sting like a Bimmer!:)
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  #248
                  Awesome work! I agree the pilot bearing should have dust seals, I've never seen one without them.
                  • The Dark Side of Will
                    • Jun 2010
                    • 2796
                    #249
                    I've read about Metric Mechanic Getrag 265 overhauls replacing some stamped components of the shift linkage inside the transmission with billet versions, making the transmission much more tolerant of hard shifting abuse.
                    • jhaurimn
                      • Nov 2012
                      • 2224
                      #250
                      Replaced fluid with mt90 today. No difference. Hope to have all parts in by next weekend to pull the transmission.
                      Current:
                      1989 325i
                      1988 M3
                      1987 325ic
                      Past:
                      2001 330ci
                      2001 M3
                      • TimeMachinE30
                        • Jun 2014
                        • 3749
                        #251
                        OEM floor mats or where did you get those?
                        ACS S3 Build / Dinan 5 E34
                        • jhaurimn
                          • Nov 2012
                          • 2224
                          #252
                          Yes, oem floor mats.
                          Made some good progress this week. :)
                          Earlier this week I started swapping out ignition parts to try and get my engine running well again. I started with a lightly used spare set I had laying around.
                          No change. So I called up a friend ;)
                          Thankfully I knew someone with an s14, so I swapped his spark plug wires to see if that made a difference. Which it didn't. At this point I'm starting to think possibly low fuel pressure or a vacuum leak was to blame for the poor running. So I replaced the fpr and the fuel hose attached to it.
                          You can see the fuel line was in rough shape.
                          This didn't make a noticeable difference either, but I got a good deal on it and it was easy enough to replace.
                          Fast forward to yesterday. Now, a huge thank you to my friend Erik, who makes a lot of the more trickier stuff possible. I went over to his shop expecting to just replace a steering knuckle and fuel pump. However, plans changed a bit.
                          The first thing we did was pull the rear seat and inspect the fuel pump. When we pulled the cover on it, we saw a very nice looking pump. When we plugged some power into it, it ran and sounded healthy. To make sure, we measured fuel pressure, which came out correct.
                          So then we started decided to try and swap the coil as thats the last ignition part I haven't changed out yet. Again no difference. So Erik starts poking around when he pulls out a vacuum cap from the throttle bodies. And to our confusion, the engine ran better. So at this point we are thinking vacuum leak and or dirty icv. I have intake gaskets and icv hoses on order, so hopefully I can get those replaced next week.
                          Next on the list was the steering knuckle. Why did I have to replace it? Well take a look at this piece of work.
                          The knuckle had to be shortened to fit the z3 rack I replaced last year. Someone thought it would be a good idea to just stack a bunch of washers on top of each other....So, I had to order one of these.
                          Thats better. The steering feels much more solid as the knuckle fits over the steering rack and column splines properly now.
                          Because the knuckle job went smoothly, and I brought all my parts with me, we decided to swap the new aluminum control arms, ca bushings, and sway end links out. Everything went smoothly with that as well, but for the life of us we couldn't get the new ca bushings onto the control arms. Lazy solution? Install treehouse control arm bushings that happened to be laying around.
                          So, we are about to be done for the night when Erik went to the back of the car and turned the rear wheel. Guess what happened....the other rear wheel didnt turn.....
                          So yeah....more pleasant surprises. But whats nice about working in a bmw recyling shop is that there just happened to be a 104k mile, 4.10 lsd available to save the day. :D
                          The diff did not go quietly into the night however, and we ended up working until 1am that night. I had work at 7am, but priority goes to the m3 ;)
                          Current:
                          1989 325i
                          1988 M3
                          1987 325ic
                          Past:
                          2001 330ci
                          2001 M3
                          • CorvallisBMW
                            • 13039
                            #253
                            Awesome, good to see she's coming back to life :)
                            • Bimmer_man
                              • Jan 2013
                              • 1477
                              #254
                              I'm a little curious are you planning on keeping it the stock base m3 or are you going to get the Evo styling?
                              • 2mAn
                                SeƱior Mod
                                • 20954
                                #255
                                and that statement right there is why you are a winner :ST1G:
                                edit: Did you replace the regular E30 control arms with the M3 aluminum ones? Do you know how much of a weight difference it was?
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
                                Make R3V Great Again -2020
