My euro 320i/B6 3.5 Alpina Tribute ( Now with turbo power)
I honestly only did it cause i couldnt fit oem heat shields and wanted some form of shielding so i got that stick on shielding rated for 2000degrees and the wrap.Comment
man I hope pandaboo wasn't speaking from experience :sad:I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
Yea that would be bad. I'm gonna stop and get a fire extinguisher to carry around. Even though If they go I probably wont get it out I sure will try. I also think that I got the wrap car enough down that most oil that would drip should burn off the manifolds before reaching the wrap.Comment
What was the hold-up preventing you from using the exhaust manifold gaskets?Comment
Exhaust manifold gaskets? No problem with gaskets i was having problems with heat shields cause my floor boards aren't the same shape as oem cause my rust repair so i had to come up with an alternative way to keep heat from transferring through the floors into the cabinComment
Went out to the car today and replaced the ignition switch with a new one i had laying around. Car now runs YAY! But still has no brakes. I've pretty much narrowed it down to the brake booster. This sucks because there is a good chance the m30's intake manifold will get in the way of booster replacement and I'm gonna have to rip this bitch apart... Now the question is do I wanna spend 209 on a 944 booster from blunt or buy a used one and run the risk of it going bad.. Cause I Don't really have the spare cash right now to drop on a booster and possibly a MC depending on the shape this one is when i get it torn apart. Pics i took yesterday but left my camera at the shop -_-
videos of my problems
Ah, misunderstood. Thought you meant the heat shields at the exhaust.... males sense.Exhaust manifold gaskets? No problem with gaskets i was having problems with heat shields cause my floor boards aren't the same shape as oem cause my rust repair so i had to come up with an alternative way to keep heat from transferring through the floors into the cabinComment
I have been thinking the same. I dont have my tach wired in yet that will be done tomorrow. I was gonna do it today but only had 12 gauge wire and I didnt wanna use wiring that big for that gonna get smaller gauge wire tomorrow and then wire it up and see. Cause yea it sounds like its idling around 1000-1200.Comment
Those pics man........ perfect.
That euro valance - took me 2 years to find one for my vert lol.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Do you have no brakes or just very hard brakes? IIRC there's a check valve in the booster vacuum line that is easy to get reversed, meaning no vacuum-assist.Comment
ZERO brakes and I'm not currently running a check valve so its down to the booster and MC and Im thinking booster. My buddy has an IX booster hes gonna sell me for 50 bucks and if it goes out i get my money back so thats why I'll be doing this weekend is putting in an IX booster. Im gonna go pull the MC today and see if maybe just maybe I blew the O ring on the MC and that causing my problemsComment
