Taco's hopes and mostly dreams.
  • TheTacoMan
    • Nov 2011
    • 2308
    #181
    Originally posted by efficient
    so was the holset turbo real?
    For all the research I did, and after taking it apart a bit I believe it is real, I emailed Holset 4 times to confirm it but they never responded once.
    As for wrapping the exhaust, I am not going to, I may get a turbo blanket down the road again.
    • kamotors
      • Nov 2007
      • 7102
      #182
      Its a beast
      7speedshop.com
      • TheTacoMan
        • Nov 2011
        • 2308
        #183
        It was at about 15psi there. Among being so violent with good traction, I lost an exhuast hanger, if you look close my exhust is a little low, and bent 4 guibo bolts in two pulls like the video. This is the 3rd time Ive either bent or broken a guibo bolt in half. I need to find some really high grade bolts, stronger than stock.
        I have some more timing to put into the tune, refine the tune a bit then a bigger meth injector to get ready for the supercharger. I may do a virtual dyno with this holset just to see what it makes one 19-20psi, just cause.
        • e30nub
          • Jun 2008
          • 1741
          #184
          Those bolts look grade 5 to me. Get some grade 8 in there
          Edit: If it's anywhere on the drive train, you should be putting in grade 8 or higher
          -Pierre
          1987 535is
          1988 325is
            • 37833
            #185
            Yes those look like some generic Home Depot bolts, no? Just order new OEM stuff.
            Looks like fun though! I need to up the boost on mine...
            Grover Beach, California
            BimmerHeads.com
            • tinkerputzer
              • Jun 2008
              • 508
              #186
              OEM guibo bolts are grade 10.9 iirc.
              • kamotors
                • Nov 2007
                • 7102
                #187
                I dont know if any of you followed his last thread but even OEM bolts bent and broke.
                this car is too grippy and violent it was on an OEM guibo as well.
                7speedshop.com
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  #188
                  Emailed Blunt, gettin dem guibo bolts.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #189
                    Things is a beast I love it.
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5284
                      #190
                      What size is your guibo? If you aren't running a large guibo/DS/trans output, maybe it's a good idea
                      Originally posted by priapism
                      Originally posted by shameson
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #191
                        Blunts order should be in soon so Ill run those and if/when I bend those I will go from there.
                        • blunttech
                          • 12850
                          #192
                          Wow ... i need more time. I miss all the cool shit. Your car is awesome..
                          sales@blunttech.com
                          www.blunttech.com
                          Like us on Facebook
                          • TheTacoMan
                            • Nov 2011
                            • 2308
                            #193
                            A little second gear on this mornings drive.
                            • ak-
                              • 12422
                              #194
                              What were the symptoms of a broken bolt?
                              1991 325iS turbo
                              • crappycoco
                                • May 2014
                                • 250
                                #195
                                Holy shit I'm getting moist from all the porn.
