Taco's hopes and mostly dreams.
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    #61
    I was just thinking about a ps13 style spoiler as well, nice choice
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
    • TheTacoMan
      • Nov 2011
      • 2308
      #62
      Ill be getting later down the road for sure, its about 220 shipped from across the world.
      On another note is the cam gear suppose to be slightly off at the bottom?
      • Ether-D
        • Sep 2011
        • 2838
        #63
        Something is certainly going on in the cam gear pic. That's not supposed to be like that. Is it pushed all the way on and lined up and whatnot?
        Originally posted by Andy.B
        I was born on 3/25…
        • kamotors
          • Nov 2007
          • 7102
          #64
          we have turned the engine over multiple times and its always like that for some reason. From what i've seen aftermarket cam gears seem to have problems with aligning the teeth on the t-belt. not sure how to fix the problem, as you rotate it climbs on correctly but obviously nothing like OEM.
          7speedshop.com
          • Ether-D
            • Sep 2011
            • 2838
            #65
            Could you add more tension on the tensioner?
            I was born on 3/25…
            • kamotors
              • Nov 2007
              • 7102
              #66
              if you physically pried the tensioner than yes, but the belt is already a very tight fit, so it would likely cause issue to go much tighter.
              7speedshop.com
              • IronFreak
                • Dec 2012
                • 3702
                #67
                will it walk off? like skip a tooth, concerning as I have one of these waiting for install......
                Get MR325 in here and see what he says, I along with Taco purchased them from him at Bimmerheads.
                Instagram @rebellionforge
                • kamotors
                  • Nov 2007
                  • 7102
                  #68
                  I think it will be fine as it will climb right on a soon as it rotates, but.... thats still not how its supposed to be.
                  7speedshop.com
                  • LJ851
                    • 7919
                    #69
                    Correct.
                    Lorin
                    The M30 is God's engine.
                    • kamotors
                      • Nov 2007
                      • 7102
                      #70
                      since its been installed for a few days I'll see if I can get some more tension out of it safely, maybe its stretched a bit since first install
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #71
                        and fixed, needed more tension, had to use a wrench to apply medium pressure to the tensioner and then push the teeth into place lightly by hand. I'm guessing thats becasue the gates racing belt is so much tighter fit than a contitech is. The spring on the tensioner is no where near strong enough to apply pressure to the belt on its own. Spins nice and smooth now and lines up every time.
                        7speedshop.com
                        • Overlord475
                          • Dec 2010
                          • 799
                          #72
                          Good to know, about to install one of these gates racing belts
                          --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
                          • Ether-D
                            • Sep 2011
                            • 2838
                            #73
                            I gotta admit, I looooove that blue timing belt.
                            I was born on 3/25…
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #74
                              If you are planning to take your engine apart I got mine from BluntTech for around 35$ I think.
                              • TheTacoMan
                                • Nov 2011
                                • 2308
                                #75
                                So the plan is to get this running in the next week or so with just the turbo. I am going to get data on intake charge temps, when I see 1 psi and when the turbo fully spools. I want to get these baselines to see exactly what changes when I add the supercharger to the equation. Everyone Knows that superchargers are not as efficient so I expect to see a rise In charge Temps.
                                I want to shoot for about 17psi, driveability is important to me. No need for a burn out machine :D
