Taco's hopes and mostly dreams.
  • Ether-D
    • Sep 2011
    • 2838
    #76
    Originally posted by TheTacoMan
    No need for a burn out machine :D
    Right!? I don't need a bunch of youtube hits, just an awesome car.
    Originally posted by Andy.B
    I was born on 3/25…
    • kamotors
      • Nov 2007
      • 7102
      #77
      I shall make your intake temp predictions now.
      10-15degrees above ambient from 1-5 psi
      Ambient from 7-10psi(when meth kicks in yo!)
      Rising to 120degrees at 7k at 17psi
      7speedshop.com
      • Northern
        I like cupcakes & sh!tboxes
        • 5237
        #78
        Keep an eye on that tensioner, it may not like the extra pressure.
        Originally posted by priapism
        Originally posted by shameson
        • TheTacoMan
          • Nov 2011
          • 2308
          #79
          Ill keep an eye on it. Now Im just trying to figure out how Im going to setup my two step and clutch pedal switch.
          • TheTacoMan
            • Nov 2011
            • 2308
            #80
            Autocross is this weekend, Challenge accepted to finish the car in time. 90% of the time rushed things end badly but this is for auto-x. :hitler:
            • squidmaster
              • Aug 2011
              • 2666
              #81
              Good luck! That's a tight deadline
              • JCarp90
                • Feb 2011
                • 1759
                #82
                You should also setup flat shift. Just because.
                • IronFreak
                  • Dec 2012
                  • 3702
                  #83
                  I want to be like you when I grow up
                  Instagram @rebellionforge
                  • TheTacoMan
                    • Nov 2011
                    • 2308
                    #84
                    I could, I probably will but it may result in alot of sideways action.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #85
                      Waste Gate is all welded up and manifold is mounted. Now to marathon tomorrow and get some shit done.
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #86
                        Wasted spark wired, intercooler piping is all cut and bolted up, iat sensor tapped and threaded, All wiring re-done with a second fan added for more cooling, Boost controller moved to a trick location, new oil filter relocation lines, new m3 oil filter for more intercooler piping clearance ( Went all 3in diameter), mounting euro valence piece, new wheels spacer out back to be temporary until bigger wheels are acquired ( Now -18 offset in the rear.), New Cps as I ripped the wire on the last one, turbo is clocked/ drain flange mounted and I think that is it for today.
                        Long day :yawn:
                        And some bad phone pictures.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #87
                          That last picture like awesome.
                          • TheTacoMan
                            • Nov 2011
                            • 2308
                            #88
                            More shitty cell phone pictures.
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #89
                              We can all learn a little to double check fittings, the one thing we didnt check was the oil filter re location and you can see the result. Didn't leak at idle but one rev to 5500ish and I made it rain oil.
                              New turbo setup is all installed and ready to go for the most part, exhaust needs to be finished and then alot of tuning.
                              Two-step/ Flat foot shifting switch, Im putting another switch for Wideband and boost light behind it.
                              What oil.
                              • MPLFoster
                                • May 2013
                                • 1490
                                #90
                                break out the kitty litter...
                                sweet FI setup tho.
                                form.follows.function IG @mplfoster
