Taco's hopes and mostly dreams.
  • IronFreak
    • Dec 2012
    • 3702
    #91
    Looks like the Skittle Dragon farted in your engine bay..........
    Way to go man, looks great, sounds even better.
    Instagram @rebellionforge
    • TheTacoMan
      • Nov 2011
      • 2308
      #92
      Thanks guys, this time around ill tighten the oil filter relocation kit down.
      • efficient
        • Feb 2012
        • 3312
        #93
        damn, nice to see your car coming along nicely. I'm thinking of selling the kit i bought off of you. :/ ugh life!.
        • TheTacoMan
          • Nov 2011
          • 2308
          #94
          Turns out I used the wrong thread on my relocation kit this entire time and what you see in the pictures could have happened at any point in the past. waffleswaffleswaffles!
          Thats all fixed and I was able to drive it a bit and get into boost a lil, Also got half the exhaust on. 3in down pipe to dual 2.5in with a small resonator.
            • 37829
            #95
            Awesome!
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Nisse Järnet
              • Aug 2013
              • 1221
              #96
              Cool man :)
              E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
              E30 M50 6 spd 764whp @ 24psi.
              E30 M20 6 spd 675whp.
              • Denny
                • Jan 2010
                • 822
                #97
                Good job man :)
                Denny
                ___________
                1990 BMW red 325IC M30B35 all stock Girlfriends ride
                1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                Blogs:
                http://bmw325e30.blogspot.com/ (restoration)
                http://bmw325e30turbo.blogspot.com (Twincharge M20)
                http://bmw325e30m62b44.blogspot.ca/
                • e30m3s54turbo
                  • Jun 2010
                  • 3257
                  #98
                  Sounds sweet.
                  • 325ix
                    • Aug 2009
                    • 7783
                    #99
                    The flares on flares has really grown on me. I really would love to own a turbo m20 one day.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #100
                      Thanks guys
                      Lengthened and got another mount to the subframe for the exhaust and also changed out the dead driveshaft. NO MORE CLUNKING
                      Also rewired the gauges into a new switch, sense I am able to see my AFR now I did a second gear pull at 13psi. Its globs faster than more old setup already and at less boost. I cant even imagine it at 18-20psi.
                      Back in the garage.
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #101
                        Got around to mocking up the grill finally, makes me happy that they do fit the fiberglass pretty well.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #102
                          Boost rising to around 18psi at 7k. Missing around 8 degrees of timing in boost to get everything dialed in. Should see a big increase in power once we get it tuned better. Hopefully can get some more torque out of it.
                          7speedshop.com
                          • MyE30
                            • Sep 2013
                            • 326
                            #103
                            ka, what is your target AFR in terms of boost pressure? are you going to clean up the AFR a little more before messing with the timing?
                            i know there are many different schools of though on tuning turbo motors, just wanted to hear what yours is.
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #104
                              I have a 13psi spring in the wastegate currently, will chase the boost spiking issues. Some more tuning, a bigger meth injector, more timing and it should be even faster.
                              Carpets were also shampooed and gauges were remounted.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #105
                                I get the afr to a constant 11.8, maybe 11.5 at peak, then timing, then touch up afr again.
                                7speedshop.com
