M20 B3x Naturally Aspirated Stroker build past, present and future
  • digger
    • Nov 2005
    • 6170
    #391
    Originally posted by beemaestro
    I'm looking to get a new head, 44-45mm intake valves, cam 292 or up, 12.4 or higher CR pistons and ITB's (tapered 45>42mm) for this year and maybe get another 20-30HP out of it... but posting my wants here is off-topic I guess :D
    that should make a big difference to power but it is hard to find good head porters though. if you only gain 30hp with those modifications then there is seriously something wrong
    • ForcedFirebird
      • Feb 2007
      • 8300
      #392
      Hey Digger, crank hubs have been NLA fore a while. The client with the 12:1 m20b25 that exploded his damper two yr ago ('19) went with a modified ATI unit that was drilled for the m20 crank snout, then modified a v-belt pulley to suit. He is still banging 8500rpm and it's held together for the 2020 season. Pretty sure we will see some more power this 2021 season, he peaked at 208whp/198wtq last year, but when he sent his head in for a refresh in Jan, I was able to get another ~12-14cfm on the intake side from ~.200-.350" valve lift. Will post results in the dyno thread once it's together.
      Hi, they use a SuperFlow AutoDyn 30 AWD dyno if that clarifies things for you!?
      Short vid of the car on the track:
      Yes, it does. At first, I thought your HP number was a little high (hence the comment about W vs B HP). But, then realized today reading back that your numbers are metric. That brings us closer to the SAE 215lbft I have seen many times. After conversions you are making 234whp/215wtq SAE, which is right on par for your upgrades. It seems like getting over the 230whp mark is a bottleneck for these single cams without diving deep into the valve train (oversized seats, custom/roller rockers/cam etc).
      No one said the stock manifold "can't", it's just not as easy as using ITB. Just putting RHD ITB's on a bone stock m20 picks up almost 20whp.
      john@m20guru.com
      Links:
      • digger
        • Nov 2005
        • 6170
        #393
        I'm still waiting to hear back from ATI, they have been very slack in responding. i have a new OE one on the shelf and a low mileage one but its not going to be particularly well suited to mine. i'm sure it would work well in normal driving and occasional short bursts to 7500 but id like to buzz mine to 8000rpm if the power curve is sufficient to warrant
        that dyno above is a flywheel number, its not whp as how most in US or Oz would expect. he hasnt build that other engine with those specs yet it was a basic 2.7. it should easily exceed 230whp with the new spec provided it is executed properly of course
        • Mr Mpower
          • Aug 2011
          • 95
          #394
          We don’t have enough words to thank you all your info and all the time you take to learn and to share this...is priceless
          i have arrive to your post looking for a setup for my engine.
          is a m52b28 2800cc 6700rpm for street use close to stock in fact, stock cams and stock intérnals.
          I need to do a new exhaust for it and if i understand well, in your investigation for street use, the s54b32 exhaust offers a good base for it.
          So taking in mid that from OEM m50/m52 uses twins 1,75” ID for the secondary pipes and the s50b30 use twin 2,25” I thing is not bad idea to use twin 2” ID For the new one
          with that say your 2th harmonic with s54 base setup with kats sounds that best bet for me.
          so for the secondary pipe 2 twins 2”(50mm) pipes with 1600-1700 leght (kats include) looks nice in my mind
          giving that I don’t know if is better to use and H pipe or a X pipe because in your setup you use the X pipe but in the s54 setup that you recommend they use H pipe.
          about the final pipe at first I was thinking to go twin 2” too with the muffler and twin 2,125” tail pipes, ¿is worth use 2.25” for the final pipe in place of the 2”?
          I really appreciate your opinion into my setup
          https://twitter.com/PetrolHeadSpain
          http://spainpetrolheads.wordpress.com/
          https://www.facebook.com/PetrolHeadsSpain?fref=ts
          • digger
            • Nov 2005
            • 6170
            #395
            s54 as in configuration not sizes (diameters)
            i favour around 1600 mm give or take with a street engine. This is in effect a total length of 2200 mm when primary (assume 600 mm) is accounted. If you use longer primary then retain total length 2200 and shorter the collector a bit and vice versa. E.g. with long tube headers which are like 800mm often then 1400mm will work ok to.
            twin 2" is plenty unless its a crappy workmanship i.e. bad bends, misalignment, mismatch etc. A really nice twin 1.875" or 1.75" would also work but need to pay a bit more attention to the details include the muffler, cats, resonator sizes and efficiencies
            • Mr Mpower
              • Aug 2011
              • 95
              #396
              Click image for larger version  Name:	colector m52.jpg Views:	0 Size:	80.0 KB ID:	10016122
              Ok, i understand, your dedication is priceless period.
              By now, the manifolds need to be OEM so this are my primaries and secondaries, giving that like you see in the picture left side is shorter than right side, i need to staggered the kats a bit to have the same leght from the primaries?
              In this case where the primaries are so short, the 2200mm total lenght still being the best choice?
              i have read you a few times talking really good about the s54 desing but it uses H pipe and you are using X pipe finally, wich is the main reason?
              Thanks for all again, this topic must be consider as one of the best guides in the community.
              • digger
                • Nov 2005
                • 6170
                #397
                2200mm total from head for x-pipe location. since front 3 and rear 3 are different positions just take average. When you have 2200 mm length a difference of 200 mm is 10% which is not much. but if you had a system with 800mm then 200mm variance is 25% so you need to more accuarte when the system is short but not so much when its long.
                i dont think there is a need to stagger cats you cant get the two (2) collectors the same anyway
                X-pipe i think is just a better flowing H-pipe, but either will do the same job
                • Mr Mpower
                  • Aug 2011
                  • 95
                  #398
                  i was waiting for a really negative comments about the manifolds, but you are absolutely polite, hahah.
                  really than your time and effort in all this and waiting for more advances in your build.
                  • digger
                    • Nov 2005
                    • 6170
                    #399
                    Euro m3 headers would be better ;)
                    • Mr Mpower
                      • Aug 2011
                      • 95
                      #400
                      late night rethinking about this setup, the m52 is 24v and m20 is 12v, the 2nd harmonic setup you’ve designed should work fine in the 24v config aswell ?
                      • digger
                        • Nov 2005
                        • 6170
                        #401
                        Yeah length is mostly an rpm thing so 2v 4v not a meaningful difference
                        • Mr Mpower
                          • Aug 2011
                          • 95
                          #402
                          BTW in this picture, in the 2nd harmonic:
                          when you write to 2x2" at the first pipe, you are talking about 2 pipes of 2"OD i think
                          but when you write 2x2 25" in the final pipe, are you refering to 2 pipes of 2,25" OD or 2 pipes of 2" OD and 25" lenght ?? sorry for the silly question but i use metric system and sometimes is tricky to understand some things. Thanks again!
                          • digger
                            • Nov 2005
                            • 6170
                            #403
                            2x2.25”
                            • Mr Mpower
                              • Aug 2011
                              • 95
                              #404
                              2x2.25”
                              thats what i thought at first! thanks! is interesting how usually i see exhaust builds (with close to 0 science or investigation application) more restrictives in the final pipes but you develop the opposite (what i trust definitely), thanks for your help, this friday im going to apply this on my setup!
                              • digger
                                • Nov 2005
                                • 6170
                                #405
                                when i had my first exhaust done the BTB2 6-2 headers were 1-5/8" into 1-7/8" collectors and the shop just made the rear 2.25" from where the BTB collectors ended. 2.25" is more common for cats, resonators, mufflers etc so that's really the only reason it is 2.25" this was not by engineering or calculations but i didnt want to change the entire setup so left it.
