M20 B3x Naturally Aspirated Stroker build past, present and future
  • zwill23
    • Jul 2015
    • 615
    #421
    I swapped my booster and master for an E93 unit as well after looking at prices for standard E30 boosters. Even with stock brakes, massive improvement in pedal feel and considering the price point and ease of modification this is a no brainer.
    Car is looking lovely as always
    • skarlqvist
      • Nov 2024
      • 5
      #422
      It is all about the total package head. This awd dyno result is from my m20 low comp na stroker build. It pulls harder than an original s54. With a bigger cam there is a lot more to gain.
      • digger
        • Nov 2005
        • 5977
        #423
        That is a nice curve, would be interested if you could post more details
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5343
          #424
          2nd
          Current Collection: 1990 325is // 1987 325i Vert // 2003 525i 5spd // 1985 380SL // 1992 Ranger 5spd // 2005 Avalanche // 2024 Honda Grom SP // 2024 Yamaha XSR700 // 2024 Jeep Gladiator Rubicon
          • skarlqvist
            • Nov 2024
            • 5
            #425
ID:	10130595Click image for larger version
            ACSchnitzer S3 IXT with VW T5 Ronal wheels, Original M3 fenders with rework for read doors and handles.
            E36 compact hubs in rear and E87 rear hubs in front. Aftermarket big brake kit.
            CNC ported AMC head 43/37. Flows 173/134 at 10mm lift
            89,6mm M54B30 crank
            DP pistons 86mm/135mm Compression 9.0:1
            Full RHD roller cam kit with (AGAP roller cam 296gr)
            DBilas itb 45mm MaxxEcu sport
            Headers with 2x2,5" stainless exhaust and dual race cats.
            • hasa
              • May 2013
              • 288
              #426
              Thats better than what I'd expect for standard compression and 173CFM head! Nice packet.
              • digger
                • Nov 2005
                • 5977
                #427
                ~240whp (281bhp) seems about right for that, though i would expect it to peak at higher rpm with the short runner dbilas intake but this might be a lazy dyno tech not setting up rpm correctly. Personally i would consider the RHD inlet it is far superior perhaps except for the OEM looks or lack thereof
                • skarlqvist
                  • Nov 2024
                  • 5
                  #428
                  280 whp in an ix on a awd dyno with perhaps 15% drive train loss is a dead race against an original S54 (tested on the same dyno).
                  There is room for an additional horses if you go for the 302/309/316 roller cams (street-ability will suffer, this is none vanos engines).
                  The RHD roller setup allows for revving to 10K but the 89,6mm crank in my car translates to a pistonspeed of 25m/s at 8400 rpm.
                  Piston speeds of 25m/s is the upper limit in most engines.
                  The original m20 oil pump will start to cavitate at 8000+ so the real max rpm is actually 8000 (one must move to dry-sump for higher revs).
                  My engine is build for boost and >500Whp. If I was to keep it na I would have gone for RHD itbs, any day.
                  I have been talking to DBilas and they have pressure tested the plenum and itb construction for 2 bar.
                  For this car I have bought an Australian "Raptor V" supercharger and since the ix front diff is the weakest part I will limit power to 500whp on pump gas.
                  The engine needs a lot of air in and out. I use AEM Dry flow 76/135mm and the custom build 2x2,5" exhaust below.
                  • litu
                    • 824
                    #429
                    Wow, that engine in ix. We want more, way more info...Is there any where i can follow this project
                    https://www.facebook.com/Cry_77_IX-110483784967661
                    https://www.instagram.com/cry_77_ix/
                    • skarlqvist
                      • Nov 2024
                      • 5
                      #430
                      A proposal for the ultimate screamer:
                      Move to dry sump, Use a 2.5l crank, Port the head, Bore the cylinders from 80 to 87mm, Use hi-comp pistons 12:1, Use RHD itb and roller kit with 316 cam.
                      Add a really light fly wheel and clutch pack and rev this 2,7l m20 to 10K.
                      This will give you more than 300whp at piston speed 25m/s and with the right exhaust a sound like a Honda CBX1000 ;-)​
                      • litu
                        • 824
                        #431
                        Nam nam
                        • skarlqvist
                          • Nov 2024
                          • 5
                          #432
                          If you want to run classic wheels and a big brake kit. K-sport is a nice alternative. This kit has 3 piston callipers and 350mm rotors. I have tested it to work with all the 18" wheels I like.
                          Order a 325mm rotor and it will clear 17" also.
ID:	10132462Click image for larger version
ID:	10132463Click image for larger version
                          • leez
                            • Jul 2012
                            • 3
                            #433
                            Any updates for us digger
