Kadunza S54 ITB Adapter Plate Project
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Originally posted by digger
    i recommend putting the adapter with a head and a runner on the flow bench, there are easy gains getting the transition and alignment between runner and head sorted.
    the difference between a good adapter and poor one is 10-15whp. i'm not familiar with the real estate you have and other practicalities but the longer the adapter the better the transition will be. it will also make the runner volume smaller which is good when you have big throttles
    If they really wanted to make power they would avoid this setup all together and just get an S54.
    • LJ851
      • 7919
      Hee hee.
      Lorin
      The M30 is God's engine.
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        • M-technik-3
          • 18946
          Sweet nice work
          • dude8383
            • Jan 2005
            • 10387
            Been watching your progress on FB. Needless to say I'm super happy to see that you guys are moving forward with this.
            • flyboyx
              • 8371
              yes, there is that. however, some people already have s5x's in their car and don't want to spend another 5k+ to reswap. if this setup, a set of schricks, a 540i hfm, and a TRM tune can add 30-40+ hp, it will be a better option for me and perhaps a lot of others.
              i am actually amazed you were able to get the throttle position sensor to clear the vanos solenoid.
              as far as throttle linkage, can you just take parts off the stock single barrel throttle body and modify them a little?
              Gigitty Gigitty!!!!
              • Jalves619
                • 596
                For someone running a standalone, will the vacuum "log" provide an adequate map signal? I wouldn't want to run alpha N because I intend to run FI as well.
                • digger
                  • Nov 2005
                  • 6191
                  seriously where is the fun in that?
                  lots of ITB kits avilable these days no excuses for not making big power from non S engines
                  • CoreyZ
                    • 384
                    The bottom end exploding at higher revs is a good one!
                    We need more people experimenting with ATI dampers
                    • pantelones
                      • May 2011
                      • 533
                      Indeed...
                      I don't really care to investigate, but are these even close to being the right size for most s/m5x motors? I know that most of the ITB's for the m20 are wayyy to big and are not maximizing their efficiency. I have a feeling that you would need a pretty well built motor to effectively utilize the s54 ITB, and if you are spending that much $$$ you probably would rather buy an entire kit that is custom to your set up. It's a good idea, but there is more to a motor than just slapping some cool parts on it and saying FUCK YEAH! Since you're in this deep, proceed... :popcorn:
                      A man chooses, a slave obeys... Would you kindly?
                      • digger
                        • Nov 2005
                        • 6191
                        from what i found
                        M50 manifold is 55x25 and M52 is 45 x 23 which means an equivalent diameter of
                        39.75 and 34.25mm respectively
                        • RobertK
                          • Jun 2005
                          • 5864
                          Seemed to work great for Karl's M54B30.. and from what I understand he's putting out much higher numbers now but is very secretive about what else he's done to the engine.
                          Regardless, I always love reading the remarks of desktop mechanics but I'd much rather prefer to spend the majority of my time doing than talking.
                          • IronFreak
                            • Dec 2012
                            • 3702
                            I like this guy ^
                            Carry on
                            Instagram @rebellionforge
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              schwing!
                              • CoreyZ
                                • 384
                                Holy fucknuts. 8500rpm on an M54?
                                I'm guessing it's destroked and he's using an ati superdamper among other things.
                                Too bad he's not sharing the secret sauce
