TehRaydarlover's AWD Lover
  • kid325e
    • Sep 2007
    • 6422
    #31
    Not sure if you've installed that frond driveshaft yet with the Jute piece but very interested to see what you think of the install and quality!
    Take lots of pics when doing the reinforcements on the rear subframe pleasee?!
    Sent from my Nexus 4 using Tapatalk
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • TehRaydarlover
      • Mar 2013
      • 544
      #32
      Haven't installed it yet, idk why guess just waiting until I need it. The quality is excellent, great material choice, machined with a press fit so you don't have to worry about it being on there crooked, chamfered for the weld, I am interested in seeing how evenly the grease gets distributed to the splines in the t-case.
      Will do!
      Ray
      Build Thread
      Rear Diff Rebuild
      Rebuildable Viscous Coupling
      Transfer Case Rebuild
      "Life is simpler with 12 valves"
      • kid325e
        • Sep 2007
        • 6422
        #33
        Loving all the iX builds i've been seeing lately!
        clutchCTRL!
        - 2000 323i AT
        • bradnic
          • Jul 2012
          • 3554
          #34
          late to the party as usual - SUB'D
          HOWTOs:
          DB vert plastic bumpers
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • fight4life28
            • Apr 2014
            • 821
            #35
            Nice work, What are some future plans you have for the car?. Seeing all theses IX builds wants me to just get mine back on the road again... She hasn't been on the ground for about 2 mouths.
            • TehRaydarlover
              • Mar 2013
              • 544
              #36
              Thanks! for some reason its hard for me to say what my future plans are, I have all of these little projects for parts I'm building for the car that I'm focusing on and haven't really lifted my head up to think about the end goal. I guess it would be to have an excellent oem+ look to it then when you hit the gas and take a turn it leaves you speechless. There will be a turbo in there somewhere.
              Build Thread
              Rear Diff Rebuild
              • TehRaydarlover
                • Mar 2013
                • 544
                #37
                Picked up a 370mm mtech 1 wheel a while ago. I really like my 385mm mtech 1 wheel but with my steel toe boots for work and being 6'2" I can't get in my car without hitting my knee. The stitching is coming apart but the leather is in perfect shape, its at an upholstery shop now getting restitched. Hopefully this will solve the problem or at least make it less of a hassle to get in/out of the car.
                Build Thread
                Rear Diff Rebuild
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4490
                  #38
                  h8 u 4 dat
                  • TehRaydarlover
                    • Mar 2013
                    • 544
                    #39
                    <3
                    Build Thread
                    Rear Diff Rebuild
                    • TehRaydarlover
                      • Mar 2013
                      • 544
                      #40
                      Was up at the cabin hunting last weekend, left some ix tracks haha:
                      Build Thread
                      Rear Diff Rebuild
                      • TehRaydarlover
                        • Mar 2013
                        • 544
                        #41
                        Hey guys happy thanksgiving, here’s one of the projects I’m currently working on. I disassembled and started working on a diff upgrade similar to mw044’s back in September. It’s his experience that the at least the first point of failure in the front diff are the small spider gears.
                        The idea is to cut the walls of the pumpkin off one diff and weld them to another thus adding two more spider gears, basically sacrificing one diff to reinforce another. This will help to lessen the load on each gear. With adding the two more spider gears I need to cut the shaft the gears ride on in half and machine a support block to hold the free ends of the shafts. I took a few measurements and had the support block machined out of a “tool steel” I’m not exactly sure what type of steel it’s made out of, I got the material when I was at school, it was just advertised as tool steel.
                        The support block came out quite nicely. I was a little upset after having to wait about two months to get it back when the machine shop forgot about my order and temporarily lost the material I gave them, but when I did get it back it was no charge because of the wait, I was like, wat? Oh alright, thanks! haha
                        Alright easy stuff done, now for the complicated part. This is where I thought I could improve upon mw044’s diff. My plan is to bolt the crown gear back on and weld the sides of the pumpkin to the crown gear. Then cut off the top and bottom of the pumpkin. In my mind, the geometry of the additional spider gears is critical; you must retain the original gear fitment/lash or you will have increased wear and ultimately failure. By welding the sides of the pumpkin to the crown gear I can then (after some shaping/grinding) bolt the crown gear onto another diff, keeping the cups that the spider gears ride on in the correct position.
                        Now for the welding. The plan is to grind and shape the sides of the diff so everything bolts up without any interference. Then with the crown gear bolted to the diff tack weld the additional sides from the old diff to the new diff. Then cut the tack welds off of the crown gear and remove it. Then finish welding.
                        To ensure a good weld I need to know what material the diff is made of and come up with a weld procedure. To determine what kind of steel I’m dealing with I shot it with our Niton XRF Analyzer at work. It came back as 1215 carbon steel. This is kind of bad news because while 1215 has excellent machinability it doesn’t have very good weldability due to a high sulphur content. I don’t think it will be too much of an issue because it won’t take too much to hold the sides in there and the weld isn’t going to be seeing too much of a load, its mostly just holding the sides on there. We have some extremely skilled welders at work that I’m sure are more than capable of getting the job done. Here’s the print out from the XRF Analyzer if anyone is interested
                        After everything is welded up I would like to have it sent out for stress relieving but I don’t think it would be a good idea because I don’t want to mess with the gear heat treat or that it will distort or crack the case. Once its welded I may need to skim cut the crown gear fit turn on the diff to clean up any excess weld. Then it’s just a matter of pressing on some new bearings and resealing it, then I should be good to go.
                        Any input is welcome,
                        Ray
                        Build Thread
                        Rear Diff Rebuild
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #42
                          Sweet build so far good work
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            #43
                            Nice work :)
                            E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                            E30 M50 6 spd 764whp @ 24psi.
                            E30 M20 6 spd 675whp.
                            • TehRaydarlover
                              • Mar 2013
                              • 544
                              #44
                              Thanks
                              Build Thread
                              Rear Diff Rebuild
                              • dinanm3atl
                                • Feb 2007
                                • 7305
                                #45
                                This is spectacular! Awesome work.
