Classic Daily E30 325iX S54 Swap
  • jakeb
    • 1909
    Keeping them rolling....
    The owner of this wanted something that he can drive year round (lives where it snows), has classic style (e30), and has a bunch of power (S54). So lets combine them all and make something.
    This car already have H&Rs and bilsteins which will stay. It will get new bushings all around, rebuilt axles, and freshened up all the way around. Interior will get swapped to black. (looking for seats if anyone has any black sports please send me a PM)
    This might be the cleanest iX I have ever seen. Now I haven't seen many but those that I have are rusted and rotted.
    90k s54
    iX Drivetrain dropped out
    Underside...man it's clean
    More to come in time.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • lambo
    Captain Scene Points
    • 10953
    Umm.
    Yes.
    • funcrew
      • Jun 2007
      • 1223
      Weird. Impressive but weird. Will the oddball ix driveline hold up under that kind of power level?
      "If the sky were to fall tomorrow, the tall would die first."
      -Dr. Paul Forrester
      Do I LOOK like I need a psychological evaluation???
      • 328ijunkie
        • May 2007
        • 3961
        Interesting
        Check Us out on Facebook
        Full Product Line Tuning
        • TehRaydarlover
          • Mar 2013
          • 544
          [ATTACH]85410[/ATTACH]
          Build Thread
          Rear Diff Rebuild
          Rebuildable Viscous Coupling
          Transfer Case Rebuild
          "Life is simpler with 12 valves"
          • LJ851
            • 7919
            Finland says OK.
            Does nando know about this ?
            Lorin
            The M30 is God's engine.
            • litu
              • 847
              Nice...Very interesting
              https://www.facebook.com/Cry_77_IX-110483784967661
              https://www.instagram.com/cry_77_ix/
              • jute91
                • Nov 2011
                • 581
                Looking good. Ix drivetrain will handle ~500hp easily with few small mods.. if its going to be above that you should start to think reinforcing the front diff with extra diff gears.
                Also found on Facebook - Juuso Tero, Tampere
                https://www.facebook.com/JuusosGarage
                  • 34844
                  should be fine for a stock internals S54. the transfer case is way overbuilt. the front diff isn't the strongest but if he's not drag racing it should hold up fine. People don't really understand, but drivetrains are really rated in torque, not power. the S54 has a nice flat torque curve but it's still less than what the chain in the transfercase is rated for.
                  I can only assume you are going franken pan. that will require a brake booster solution, but otherwise it's pretty much a bolt on affair. I've been working on my own for almost 5 years now, lol. I'm getting closer but I'm taking my time too.
                  I'd get one of jute91's front driveshaft spline extension peices too!
                  • rzerob
                    • Jun 2013
                    • 2315
                    Subscribed.
                    • ldsbeaker
                      • Aug 2004
                      • 3098
                      Whoa. Super sweet.
                      Slicktop City!
                        • 37833
                        Definitely looking forward to seeing this one come together!
                        Grover Beach, California
                        BimmerHeads.com
                        • jakeb
                          • 1909
                          Yes will be doing the frankenpan. I agree with nando...abuse will kill drivetrains not just power (well within reason). The owner knows he cannot be doing burnouts and clutch drops otherwise stuff will break.
                          Yes something will have to happen with the brake booster. More than likly I will go to a GM hydroboost. I've done it on other cars and they work great.
                          What's this jute91 spine extension you speak of? I'll have to send him a PM.
                          • fresh_TD
                            • Aug 2013
                            • 2457
                            Subed:-)
                            Cleanest ix you've ever seen? ..I don't know about that..lol I keep mine pretty clean though ;-)
                            Sent from my Samsung Note 3
                            '91 318i (Alpine) - daily
                            '88 325ix (Zinno) - drive here and there!
                            • jakeb
                              • 1909
                              Originally posted by fresh_TD
                              Subed:-)
                              I do live in Michigan and most iXs around me don't live very happy lives. Where they are driven in the snow and put away for the summers. So they rust rust rust. This car is not from Michigan but not all that far away.
                              Yours looks minty. :-)
