Plans for the car has changed. Going to build an m20 3.0 stroker. Strip and cage the car and make a sweet track car. Once I sell my Subaru the build begins!
Don't know what build I am doing yet...Maybe a 2.7 turbo drift car?
I would do some research on sizing those ITBs properly. Most people go too big. I think 40-42mm were a good range for the M20. Id read digger's thread if you plan on building up the M20. Also I think there is different strut caps that will drop the front 15-20mm IIRC. either way keep it upSimon
Current Cars:
-1966 Blue Boat
-1969 Red VW
-1986 White BMW
-2006 Green Thing
Make R3V Great Again -2020Comment
Thanks, through my research people are using 38-42mm and these are 38mm so sizing shouldn't be too far off.I would do some research on sizing those ITBs properly. Most people go too big. I think 40-42mm were a good range for the M20. Id read digger's thread if you plan on building up the M20. Also I think there is different strut caps that will drop the front 15-20mm IIRC. either way keep it up
And as far as suspension I'm thinking about going with ground control coilover kitComment
Probably be about the same cost and easier to drop in an s54. Just saying...2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
Yeah they just won't center up and just a few other little issues
Thats why I said "part 1"
but yes I would need 2 more
:hitler::hitler: Now wheres the fun in that. But yes your probably right. I might do a 3.0l Turbo build. My limiting factor is tires right now, but I just bought a set 17" tarmacs and tire choices are a lot more for 17's then for 15's. So I might just do some flares to run 245's and do a turbo m20Comment
If you're set on ITB's, Bullet Ride's thread has lots of great info.
If you want an off the shelf setup, check this out.Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30Comment
