ST1G's s52 OBDII Calypsorot
  • ST1G
    • Oct 2012
    • 6689
    #181
    Originally posted by ajhostetter
    Ok. We'll stop jacking ST1Gs thread.
    Yeah, I'm freaking pissed!! My whole thread is now ruined. I'll have to make a new one. He is lucky I'm not an admin
    • eduTechnic
      • Dec 2012
      • 400
      #182
      Yeah but you like salad shooters too and I bought yer grillz. Grillz + rimz besties = BFF zone. So let me tell you more about my build in this area of the forum...
      Turbo M50 4 Door Build thread here 4 Sale thread
      • ST1G
        • Oct 2012
        • 6689
        #183
        Okay fine, you can stay :pimp:
        • ST1G
          • Oct 2012
          • 6689
          #184
          Started sectioning my struts yesterday. I totally buggered up the ball joint. I couldn't get it out and after about an hour of trying to get it out I just ended up hammering it with a 5 pound hammer as hard as I could. So I guess I'll be getting new control arms/bushings.
          Here is some of the sectioning process. My hands were really dirty and covered in metal filings so I didn't take too many photos.
          I ground down with a floppy disk everywhere before I welded so I could get good penetration. I welded all the way around obviously. I was taking photos while the metal cooled after a weld.
          • bradnic
            • Jul 2012
            • 3554
            #185
            nice welds..
            HOWTOs:
            DB vert plastic bumpers
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • ST1G
              • Oct 2012
              • 6689
              #186
              Originally posted by bradnic
              nice welds..
              I can't tell if you're being sarcastic I don't have a great deal of experience welding, but think that I've done a well enough job for them to hold and not break over time. I got a nice fat, well penetrated bead all the way around the perch, which is the most important area to get a good weld on this project.
              If someone who is good at welding thinks I did a terrible job let me know so I can redo them, or have them done right.
              • bradnic
                • Jul 2012
                • 3554
                #187
                I'd never criticize someone's work on a forum.. Was sincere - looked like a nice bead and good heat/weld penetration. And to be clear I'm re-learning welding on this side too. Not an expert.
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • ST1G
                  • Oct 2012
                  • 6689
                  #188
                  I couldn't tell because of your double dots. I appreciate it.
                  • ST1G
                    • Oct 2012
                    • 6689
                    #189
                    Since school has started I have much less time to work on the car, but I squeeze work in whenever I can.
                    Tonight I got the rear driver sock and spring installed.
                    My room mate said my dimes should be closer together
                    Starting height
                    The old shock came out easy enough. It had fantastic dampening ability.
                    Dirty. Added a reinforcement plate; the photo was blurry.
                    Cut my finger on the spring compressor.
                    fixed
                    The spring is adjusted a majority of the way down. I'm a little disappointed. It's not very low. I don't know if it's because the front end is still on jack stands, if the other side isn't done, my shock is too short, or it just needs to settle. I'm really not sure.
                    • ArtFoodBMW
                      • Feb 2014
                      • 765
                      #190
                      Awshum dude!
                      • bradnic
                        • Jul 2012
                        • 3554
                        #191
                        chill til you have the other side down too.
                        HOWTOs:
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • ST1G
                          • Oct 2012
                          • 6689
                          #192
                          Originally posted by ArtFoodBMW
                          Awshum dude!
                          Thanks!
                          I'm not too worried. I'll see what happens when the fronts and other rear is on.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #193
                            I thought the GC instructions say to remove spring pad?
                            1991 318i 4dr slick top
                            Mtech 2 turbo restoration
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #194
                              I would remove the spring pads.
                              And yes it should settle a little lower once the rest of the car is lowered and on the ground. 4" or 5" rear springs?
                              Go here be happy!
                              Ratchet Garage e30 V8 build.
                              • ST1G
                                • Oct 2012
                                • 6689
                                #195
                                ST1G's Calypsorot Metallic build
                                Spring pads were removed. I only kept the top pad provided by GC
                                It's a 5 inch rear spring. Like I said, pads are removed and I maybe have 2 threads left to adjust down. I don't know if it's going to settle an inch.
