325IX restore and build continued(turbo, e34ix diff, DCT)
  • Nisse Järnet
    • Aug 2013
    • 1221
    #376
    This setup works perfect :)
    Looks good man!
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • nomansland92
      • 1657
      #377
      Ya I machined dowels into everything to locate everything, and ya I rotated the trans to 20 degrees. If I didn't have the oil pan already built I would of set it at 30 degrees for more ground clearance on the trans sump but 20 degrees it will have to do.
      I would imagine gs6-53bz would be real easy if it was used awd.
      Originally posted by The Dark Side of Will
      Thanks! Interesting. I assume you're still using the dowels to locate the T-case... are there any location features on the transmission?
      There was (is?) a guy in England trying to build an S62 AWD E30 M3. He had a similar arrangement on the back of a Getrag 265.
      BMW used the GS6-53BZ in AWD cars, so it already has a good rear housing for use with a T-case. The more I think about it and the more I see how strong the E30 T-case is, the more OK I am with just using it. I'll probably have to cut up an ATC-700 input shaft and weld it to a 4HP22 AWD output shaft to get the two to play nice together.
      ETA: oh yeah, and you're also tilting the trans to the M20 angle.
      Sent from my SM-G892A using Tapatalk
      IX being restored here
      Ix turbo build here
      • The Dark Side of Will
        • Jun 2010
        • 2796
        #378
        Bolting up the automatic E30 T-case would be "only" a matter of making the right adapter plate. Getting the shafts to play nice is harder because there wouldn't be a guibo.
        • nomansland92
          • 1657
          #379
          Really wish I had more time to get in the garage lately but I'm still hoping to be driving it this spring.
          Sent the hot side out to get ceramic coated, now I'm looking into reconfiguring the turbo drain. Its extremely tight so I'm going to hard pipe it till it clears the manifold then go to braided line and drain it into the block above oil level. Just as a note, dont drill and tap a fitting into the block were it's at in the picture for an ix, motor mount is completely in the way, good thing it's a scrap block.
          Also some new goodies showed up last week, I'll post some pics when I get a chance.
          Ix turbo build here
          • jeenyus
            • Aug 2011
            • 2064
            #380
            do you have any information on how you're attaching the front diff?
            • nomansland92
              • 1657
              #381
              Should be plenty of pictures of the oil pan further back.
              Ix turbo build here
              • jeenyus
                • Aug 2011
                • 2064
                #382
                OK, i found what I was looking for. I think i missed it. Looks pretty damn cool and inspiring honestly.
                • Garage30
                  • Aug 2015
                  • 123
                  #383
                  Amazing work! Seeing an M20 bolted to a DCT makes me warm and fuzzy inside:p
                  Euro car and parts export business based in the Netherlands, specialized in E30 Tourings!
                  Instagram: @garage30_ WWW.GARAGE30.NL
                  • Supadave
                    • 1006
                    #384
                    Build is awesome. Now I want a IX.. I see some awd drive drifts in my future.
                    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                    • nomansland92
                      • 1657
                      #385
                      Drilled and tapped the block, not gonna lie I was pretty nervous about that but it turned out perfect.
                      Bottom end and trans is in for hopefully the final time. The rest of the parts will be In for the head this week so I can assemble that next weekend hopefully.
                      Still so much work left but there's light at the end of the tunnel
                      Ix turbo build here
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #386
                        I like that AN cooling line at the back of the block.
                        • nomansland92
                          • 1657
                          #387
                          [emoji7] it's so pretty
                          Z45 cam, forged rockers, +1 valves, upgraded springs and retainers, and all cnc ported.
                          Ix turbo build here
                          • 2002tiiguy
                            • Jul 2013
                            • 467
                            #388
                            I like it first
                            • nomansland92
                              • 1657
                              #389
                              This thing is begging for 30lbs of boost!
                              Ix turbo build here
                              • 2mAn
                                Señior Mod
                                • 21002
                                #390
                                yesssssssssssssssssssssssssssssssssssssssssss
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
                                Make R3V Great Again -2020
