Ok some of you may have seen my first thread about this car and me doing the body work and suspension but heres the link to see what the car started as.
(beware the pics are huge for some reason on that tread thats why im starting a new one.)
http://www.r3vlimited.com/board/showthread.php?t=226065
In summery i stripped the car down and fixed the rust straightened it then painted it, then i replaced all the suspension with ground control coils and replaced every bushing bearing and etc... pretty much. I did that project over a 2 year span then took a break for a year to get to drive it for a change. I got almost 15k on it this summer and the car did great but now the time has came for MORE POWER!
Started by just remove the panels to keep them from getting scrated
getting everything disconnected
And we have lift off. It was actually very easy to lift the body over it. I think the biggest pain in the ass was disconnecting the shifter to later realize i really didn't have to even remove that pain in the ass clip.
After a harbor freight run i found these wheels that will hold 450lbs each for 30 bucks and they swivel! So i built this little jig that bolts to the cross member mounts and it holds pretty nice.
Did a little more stripping then i pressure washed everything and well it didn't come much cleaning haha.
Later this week I'm going to separate the motor and open it up and see how it looks inside. All my goodies should be coming in from Ireland engineering soon also.
Here whats happen with the motor
2.8 stroker
diesel forged 81mm crank
Ross racing pistons 8.5:1 comp
Ireland engineering forged rods
Full ARP hardware
The head I'm still thinking about, probably just going to order from bimmerheads. it Will have welded jackets and upgraded rockers, possible upgraded springs, maybe just maybe 1mm over valves.
I would like upgraded valve springs but im not sure if ill need them, I need to figure out what RMP i can safely get from this crank. I should be safe to at least 7k all day. Ill most likely run the car n/a for a little bit to break it in then ill add the turbo and megasquirt.
As of now i have a hx35 industrial turbo(not from a cummins), it has a 48mm compressor wheel with a 12cm exhaust. So i think i need to get a 56mm compressor wheel at least. And the price of a new compressor cover and wheel plus what i bought the turbo for is a lot for just an hx35. So I'm debating selling that for a garrett. But i know nothing about those and have no clue what size to go for. I'm still doing me research but any suggestions would be nice. Needs to be T3 and i want reasonably quick spool and i would like to see around 18+ psi with a electric boost controller.
2.8 stroker
Full ARP hardware
