E30 #2: 1990 Delphin: RHD ITB M20
  • rzerob
    • Jun 2013
    • 2315
    #226
    It sounds really good.
    • 318aye
      • Jun 2010
      • 895
      #227
      Thanks! May quiet it down in the future. We'll see.
      • craz azn
        • 749
        #228
        Wow! Dude, that sounds awesome! Makes me want an M20 again in my life!
        Rippin' Proper | Youtube | Vimeo |
        • 318aye
          • Jun 2010
          • 895
          #229
          Thanks!
          I know cluster removal has been rehashed a million times here, but I still seem to fumble my way through it every time. I ended up pulling the lower column shroud and somehow wiggled the upper one out of the way which allowed me access to remove the cluster trim, and then the cluster itself. Wheel was also pulled first. Maybe it's karma for my seemingly easy DSSR install. Remember a rag or towel to put over the column when pulling the cluster, and save yourself work when polishing the scratches out of the lens later.
          I purchased a speedo overlay, tach overlay, and trim rings from Bavarian Restoration. Communication was good before and after the sale. Apparently there was an issue with the first set of overlays, and Greg emailed me to let me know there would be a delay to ensure I received quality pieces. Always good to hear. The overlays and rings ended up shipping separately, which was a bit of a pain. Honestly, I was underwhelmed with the overlays when they first arrived. If you get up close, it seems as though the print resolution on the vinyl top layer isn't high enough, some of the indices have small jagged lines (picture dragging a line in MS paint). However, this is getting pretty close and nitpicking. I definitely felt they were nice enough to install, and once they were in the cluster I couldn't really notice that issue. The trim rings were very nicely finished and fit great, no gripes there.
          This was a handy document for me when disassembling the cluster:
          I used Nitrile gloves when handling all the cluster parts, watch out for excess powder. I found the double butter knife method the most effective when removing the needles.
          Put something down over the gauge first, and don't be stupid. They take more force than you'd think. My only regret for this project was that I marred the little screws that hold the overlays a bit. They're matte black, and almost too tiny to fix. Very hard to notice, but there. I removed the econometer (two screws underneath the original gauge face) and simple stuck the needle stop back through the new overlay. This was enough to hold it. The BavRest speedo overlay had the speedometer needle resting indicator included, so that was easily reset. The trim rings snapped in VERY securely on all four, enough so that I feel comfortable without glue. In order to install these, you need to pop the lens off. To brake the plastic weld around the outside, I used a razor blade, and then eventually a flat head with a small prying motion. Be gentle, and take your time. To reseal the lens, I used TINY drops of super glue (it wicks up under the lens, seriously use 2 drops per location). The lens was polished with Meguiars PlastX. Stick to microfiber for polishing and buffing. It lists terry cloth, but that kept turning out shitty.
          I still have yet to put the cluster back in to see if I fucked anything up (needle alignment, etc) and evaluate the lighting on the BavRest overlays. I'll post after I get it back in. I'm happy with the look overall, and I'm glad I didn't do the needles. I was really after something that appeared stock at first glance, and wasn't too flashy. Lots of their clusters have painted plastic back panels, but I like the contrast between the darker black on the rings/gauges and the lighter back plate.
          Pictures!
          • iwantspeed
            • 3164
            #230
            New cluster looks kick ass
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • rzerob
              • Jun 2013
              • 2315
              #231
              The cluster turned out great.
              • Reichart12
                • Aug 2012
                • 2165
                #232
                Clean cluster. I never would have thought black rings would look that good.
                Instagram: Reichart12
                • 318aye
                  • Jun 2010
                  • 895
                  #233
                  Thanks guys. Happy with it, glad I didn't go overboard. Here's the illumination/more finished product.
                  • Kedge
                    • Jan 2005
                    • 44
                    #234
                    Just read this from page one after coming across it via Google whilst researching the ITBs. Awesome project.
                    Twitter/Instagram - Kedge85
                    • ST1G
                      • Oct 2012
                      • 6690
                      #235
                      Love that tach. Great build mate. Wheels are superb.
                      • 318aye
                        • Jun 2010
                        • 895
                        #236
                        Thanks! Rama makes a nice product. Supposedly the airboxes are coming in a week or two.
                        Originally posted by ST1G
                        Love that tach. Great build mate. Wheels superb.
                        Much appreciated!
                        • 318aye
                          • Jun 2010
                          • 895
                          #237
                          Due in 3 weeks. Still needs a filter setup, catch can relocation, and dyno time.
                          Big thanks to Rama for his hard work!
                          • KrautnotRice
                            • Feb 2015
                            • 406
                            #238
                            Awesome man! Did Rama make these / is offering them for sale through RHD?
                            Looks like at least 3 different versions, I'm guessing S14, m20 e30 chassis, and what's the third? I *know* they're not making a m20 e28 chassis one, right? That would be too sweet...
                            '93 300TE 24V Krautbomber
                            '84 528e 5 speed Saphirblau Metallic [R.I.P.]
                            I love all BMWs with round headlights!
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #239
                              Those look amazing!
                              • 318aye
                                • Jun 2010
                                • 895
                                #240
                                Yup, Rama sent me the photo. I think these are some of his first production pieces/samples. The 4 cylinder stuff is already available through RHD, the 6 cylinder stuff is releasing very soon. I believe it's the M42 box, M50 box, and the M20 boxes in the back.
                                You should message him about fitment on the e28...not sure there.
                                Those look amazing!
                                I'm excited. We'll see how the quality is in person.
